Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > New Production Alfas
Old 01-24-2008, 05:30 PM
Graham Hilder Graham Hilder is offline
156 V6 - manual control of A/C compressor?
Greetings Alfisti,
We've just bought an early model 156 V6, and we would like to know how we can set the A/C compressor to be controlled manually, and not turn on automatically. We have heard that there is some sequence of buttons to press to make this happen, but there's nothing about this in our 156 handbook. If anyone could please tell us the details, we'd be very grateful.
(Last year, there was a post on the forum, which said: "... on the first series 156 - those with semi-automatic climate control -the A/C will turn on automatically, there is a sequence to deactivate in the handbook...")
Regards and thanks,
Graham Hilder, New Zealand
1989 156,
1982 Alfasud x3,
1971 GTV
Old 01-25-2008, 03:18 AM
Vsix's Avatar
Vsix Vsix is offline
Here is the info Fun starts @ 3000!
but I dont know why you want to change it to manual...
-Antti
156 V6 `02
http://www.carpix.1g.fi/
http://www.geocities.com/MotorCity/Factory/4940
ex cars:
155 2.0 8V -92
155 2.0 16V -96
156 V6 -98
Old 01-27-2008, 02:29 AM
Many thanks Antti - I've gone to that site and obtained the info, and will try it out some time. Reason we wanted to stop the compressor always turning on automatically was that we don't need air con in our climate, and we'd heard that the compressor wastes a lot of power and fuel - but maybe it doesn't!
Best regards,
Graham H,
NZ
Old 02-13-2008, 05:15 PM
Hello Antti,
We have printed out the manual-control procedure from the website you mentioned, but we found two problems when we tried the procedure in the car.
- First problem... In Step 4, it says "Turn the air direction knob to mid-direction position, fully to the right." Problem is that fully to the right is Demist position, and mid-direction is fully to the left. Perhaps it should say, "Fully to the left"?
- Second problem... In Step 8 it says, "Turn ignition key back to Stop." Problem is that the key is already in Stop, because we put it to Stop in Step 7 previously. So, we don't know what to do in Step 8....
If you are able to help us solve these problems, we would be very grateful.
Best regards,
Graham H
Old 02-14-2008, 03:04 AM
Vsix's Avatar
Check also the cars manual if you have it, it might be there also
found some other :
Set fan to off
Setting the temp control to maximum
Set the air flow to face
Turning the ignition to "MAR"
Turn fan to auto, off, auto and off
turn off ignition
-Antti
156 V6 `02
ex cars:
155 2.0 8V -92
155 2.0 16V -96
156 V6 -98
Old 02-17-2008, 06:31 PM
Thanks for the alternative method, Antti. We'll try that. By the way, we can't find anything in our manual about this procedure...
Best regards,
Graham
