Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > New Production Alfas
Old 01-07-2008, 09:00 PM
devonHIBBERD devonHIBBERD is offline
145 quad overheating - water not pumping though engine
my 145 has suddenly began to overheat. it seems as if there is no water pumping though the engine. the heater has also stopped working.
what parts could be prone to breakage that would cause this problem?
1998 alfa romeo 145 quadrifoglio
Old 02-27-2008, 01:52 PM
oldschooleuros's Avatar
oldschooleuros oldschooleuros is offline
Old thread... Ever resolve the issue?
A stuck closed thermostat would certainly cause some overheating issues. Check the cheapest, work towards the pricey stuff.
Matt
When cornering hard.... It's not the tires screaming... It's the road begging for mercy.
1985 Maserati Biturbo, 5spd. A work in progress.
Old 03-02-2008, 08:59 AM
Erik Erik is offline
Might also be the propeller at water pump worked loose, not the first time it happen.
Anyway, hope you had the problem solved by now.
Erik
Old 05-01-2008, 10:54 AM
treborblack's Avatar
treborblack treborblack is offline
Erik
this happend to me too. easy check is to take the reservoir cap off and look into it then rev the engine whilst still looking and you should see the water moving about, if not i'd be 99% certain the impeller has worked loose
Driving a September 1996 super like i stole it
