If you have alloy wheels on the 156, it could be wise to tighten the wheel nuts with a torque wrench to avoid warping.
The aluminium alloy in modern wheels is rock hard and does not budge until it melts or breaks. The steel in the brake disc is softer than the wheel, and when everything heats up, something's got to give. If the wheel nuts are tightened with varying torque they will warp the disc temporarily until the disc cools and settles back. Repeat this 500 times and even the best steel discs will suffer.
Brake discs get extremely hot even if you drive and brake normally. Try braking as hard as you can from 50 km/h / 30 mph with cold brakes, then touch the discs with your hand. They're too hot to touch.
Now, imagine the kind of temperatures you'll have when doing prolonged or hesitant braking on the motorway at twice the speed ...
'91 164 TS (Ford) // '99 166 3.0 (La Divina) // '72 Montreal (La Tempesta)
Ex '04 147 2.0TS Arrabiata Veloce (Zaphod)
