Old 08-14-2009, 05:04 AM
Roadkill's Avatar
156 '02 blows no air to the windshield
The results are obvious: lots of fog unless you run the aircon. The fan itself works and all the other places get their share of air.
Has anybody experienced this and if yes, what was the remedy?
- Timo
Old 09-10-2009, 02:34 PM
driver33's Avatar
This is a fairly common fault with the 156. I had a new heater box fitted under warranty to fix it!
Apparently the deflector plate warps and then sticks. I have been told that if you remove the cover on the top of the dash it is possible to run a sharp blade around the plastic deflector plate to make a bit of clearance. Having done this it should be possible to assist the motors to move the plate. It doesnt need a tight fit as a little air leaking past will make no real difference.
Hope this helps.
Good luck.
David
Alfa 156 Sportwagon 2.4 20V / 156 Sportwagon 1.8 TS / 145 1.8 TS / Spider S4 / Fiat Punto 85SX / Matra Murena 2.2
