I own a 2002 Alfa 156, 1.6 cc. On startup the engine is very noisy for a few seconds. I have had it into Alfa Dealers who keep telling me it's 'normal' and caused by the oil not yet getting to the CAM regulator - I don't know anything about mechanics but this does not seem right to me. I would appreciate if anyone has experienced the same problem, can detail the actual cause or confirm if this is a real problem to reply.
It's probably the camshaft timing variator on it's way out. As long as it's only noisy on start up, it doesnt matter really. When your cambelt is due for a change have the variator changed aswell, as the cambelt have to come of to replace the variator. No need to have the same job carried out twice.
Does it make a ticking sound? That would indeed be the hydraulic lifters trying to pump the oil through. Can be quite normal, especially when cold. It might also be an indication that you need an oil/oil filter change. When did you last get your oil changed?
cheers
Lev
Related Threads
Alfa Romeo Forums
2.1M posts
88.6K members
Since 2002
