Alfa Spider power top problem - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 07-31-2016, 09:52 PM Thread Starter
Hey all,
Once the car is turned on, every few seconds the winder motor for the power top engages (with an audible clunk). Since the top is up and not being retracted, this does nothing and after about a second the motor disengages. It repeats this process continually.
Probably related to this, the top no longer functions -- the hood under which the top is stored when retracted will not open, undoubtedly because the winder motor is not detensioning the cables.
I'm capable of removing the motor (I've done it before), but I'm curious what could be causing this periodic motor firing. I've checked the obvious things (like making sure the switch on the side isn't being pressed by the seat).
Thoughts?
topdown is offline
post #2 of 5 (permalink) Old 08-02-2016, 08:44 AM
I have recently on the Danish Alfa Club's web read about a top problem - mostly due to some leak in the hydraulic system
Perhaps with translategoogle.com you can get ideas of your issue.
Alfa Romeo Klub Danmark - Hydraulikolie og -cylinder kaleche
Erik is offline
post #3 of 5 (permalink) Old 08-02-2016, 02:04 PM Thread Starter
Hey Erik!
Thanks for the reply! The problem in this case is with the electric motor, not the hydraulic rams (I've heard other people talking about hydraulic problems, but in my experience that part of the system is pretty reliable).
This morning I unplugged the motor and gave it a few whangs with the back end of my screwdriver. That seemed to fix it. Still no idea what caused the malfunction in the first place, but some good old orangutan engineering fixed it right up.
(For the record, smacking vital components with blunt objects isn't my USUAL method of problem solving, but in the case of this motor it seems that sometimes the plastic gears can get stuck or slip somehow and a good thwack will set them right).
topdown is offline
post #4 of 5 (permalink) Old 08-02-2016, 03:22 PM
If it helps its all right !
Erik is offline
post #5 of 5 (permalink) Old 08-04-2016, 10:26 PM
kens's Avatar
My nylon gear cracked, locking down the release. Replacement gears have been made, try an eBay search if yours is broken.
In addition, with a gear in good condition, all too often binding would happen so that the lid release would not operate. The motor and gear is designed so that pressing/squeezing the housing toward the back of the car, serves as an emergency release. I leave the cover off for easy access. Place hands on each side of the housing, a firm grip will release.
kens is offline
