My Alfa 147 has covered 95,000km and just recently over the past 3 weeks, two problems have arose within days of each other. My first problem had to do with the remote central locking. Firstly, the radius for it to operate became very poor (about 5m was the maximum distance). Then sometimes it would not even work at all (the unlock, lock and boot release buttons). I've since replaced the key with a brand new battery but this didn't alter anything. I've tested both the main key and spare key, but the problem remains. When I press the button, the light on the key flashes once only briefly, and sometimes if I push the boot release button you can hear a click in the boot (as if it has almost released it).
About a week after these problems arose, sometimes when I go to start the car you can hear the engine try to kick over but it won't. Once I remove the key and start it again it is fine (it always seems to work on the second try). This has only happened to me four times over the past 2 weeks (so it's intermittent), and barring one occasion, the problem seems to occur when I try starting after I haven't used the car for 6+hours. Also I should mention, NO failure lights stay on.
I've taken it to the Alfa Dealer and as you would expect the car worked perfectly when it was there (even the radius for the remote central locking appeared normal). They've recoded the keys and had a look at the ignition and engine (including spark plugs), but otherwise couldn't find any problems at all. I got the car back yesterday and this morning when I went to use it, I tested the lock button on the key, it worked. But then when I went to unlock it, it wouldn't - so had to unlock it manually. I went to start the engine and this time I couldn't even hear it try and start! I remove and replace the key, this time I can hear it try and start but won't. The third time it started normally. I then drove down the street and back. Turned it off. On. Off. On. Without any hassel. Tested the remote central locking - which worked fine except for the poor radius again.
I'm thinking the issue may be with a failing transponder for the remote central locking which may fail to disengage the engine immobilizer, causing this intermittent ignition problem. But then how come it started on the second attempt?? Perhaps the two problems aren't related.
I would GREATLY appreciate your input on this matter,
Thank you.
Thank you.
