Friends,
three weeks ago, I detected a leak on the cooling system of my 156 2.0 TS. Specificaly, the heater interexchange oil-water shows a little hole. (do not know the english name for that part. It is right next the oil filter, and it is made of aluminium)
My work shop did the job. Not a particulary hard one, but quite expensive here... (U$S 300)
Yesterday, I detected a very unusual beheavior of the temp gauge...It get 100 degrees (celcius. 95 is normal), so I pull over, opened the hood, and saw the same leak on the same piece, in the same place.
It is a normal fault in 156??? should I suspect that my work shop never did the job in the first place? is there anything that may cause the fault on this part??
please help me since it may end the relationship with my work shop....
thaks a lot.
thaks a lot.
