The factory gap on a lot of spark plugs are set to accomodate all kinds of engines. Around 0.7 to 0.9 mm is common. The spark gap is not holy writ though. I'd set the gap to 0.9mm and go from there. With electronic ignition (like you have) with plenty of oomph, going higher than the factory gap should be no problem.
thanks for that reason is when you put the accelerator down it stutters and doesn't go, it feels as though it does want to but just wont speed up and splutters a bit, i.e fuel and no spark.
Stuttering can have several causes:
-dirty throttle chamber
-broken lambdasonde
-spark plugs that need to be replaced (for TS it's every 60.000 kilometer)
-dirty/broken 'stappenmotor' (in dutch don't know the translation,...
Related Threads
Alfa Romeo Forums
2.1M posts
88.6K members
Since 2002
