Old 06-20-2008, 07:46 AM
grale grale is offline
Turbo boost
What is de Max turbo boost possible on a 75 Turbo without touch on the electronics?
I read somewhere that the ECU can manage everything up to...
The stock boost is 0,7 bar to 155hp, and if I tune de wastegate valve to 0,9 how much power will it have?
Regards
Carlos Oliveira
Old 06-20-2008, 11:29 PM
Duk Duk is offline
Either put it on a dyno and attach a propper wideband air/fuel ratio meter or drive it on the road with a propper wideband air/fuel ratio meter.
Make sure air/fuel ratio's stay suitably rich (12:1 is still safe) and keep your ear's allert for the sounds of detonation.
Add some extra boost and run it again. If it isn't leaning out or detonating, add a little more.
I don't think you could acurately state a power output based only on an increase in boost. Is there any other work done to the car?
Alfa 75 Potenziata
Supercharged AW11 MR2 (soon to be twincharged)
RB20DET S13 Silvia
Old 06-21-2008, 04:26 AM
No work...
Only an increase in boost, twicking de wastegate actuator.
But with the increase of 0,2 bar, the car is much better, much faster.
I would say it add 20hp...
Regards
Old 06-21-2008, 05:13 AM
BigSwede's Avatar
BigSwede BigSwede is offline
you can easily move it way up, the electronics is not the problem. The issue is that the injectors max out pretty soon.
Mats Strandberg
GTV 2000 -77 Pics <= These are picture links you know...
75 Turbo -87 *sold* Pics <=
