Old 06-05-2008, 09:16 AM
benz-tech benz-tech is offline
how to repl milano 2.5 starter?
it seems to be pretty burried in there. any suggestions? the good part is i get to do it twice so i can get the good one out of my parts car. fun X 2!
Old 06-05-2008, 12:05 PM
slyalfa slyalfa is offline
what is it doing first. if it somtimes clicks and does not start you might just need to add a relay
try jumping the wire on the back fire wall next to the FI relay and see if it will start from there. if it does just add a realy at that spot. there is room next to the big FI relay. if you move the big one over one hole.
Now if you do need to do it. Remove battery cable on one side of the battery. Unbolt the down pipe on that side and undo the other side too but just bring the nuts to the end not all the way off. bang the down pipes to get them to come lose. it should be hanging by the left side but just out on the right(starter side)
then remove the right header. there is a heat sheld for the starter that need to come off too.
once that header is off you will have clear access to the starter. undo the wires. then undo the big boltes pull the starter. Then put in the new one rember to put the wires in that nook as you slide the starter in as there is not room to put the wire in after.
1987 black Milano Verde
1972 White spider 2000 Veloce
Old 06-05-2008, 03:38 PM
thanks for the advice
