Old 05-01-2008, 08:48 PM
benz-tech benz-tech is offline
2.5 platinum gearing question
it seems that 2nd gear is abnormally tall for a car with 4.1 rear axle ratio. my car will do over 60mph in 2nd gear. also at 60mph it is turning approx 2800rpm. 3k yields about 65+. is that normal? i do have incorrect 205 55 15's on it but that would only change the distance traveled and overall speed, not the relationship of engine rpm to speedo ratio. the speedo feels accurate if not reading a little low- which makes sense w/ the tires.
is this how your cars are geared?
Old 05-01-2008, 10:17 PM
Gubi's Avatar
Gubi Gubi is offline
Your tires are only 2% off from stock, which isn't bad. In 5th gear you should have 21.1 MPH per 1000 RPM. This works out to 9.6 MPH per 1000 RPM in 2nd.
At 60MPH in 2nd you should be at 6250 RPM, so it sure sounds like your tach is slow.
1991 Spider
1987 Milano Gold
Old 05-01-2008, 11:24 PM
Grant's Avatar
Grant Grant is offline
Maybe you have a verde differential for some reason? The gearing on those boxes are 3.55 final drive, same ratios for the rest of the gear set.
The tachometers on 2.5 liter Milanos always seem to read low. Hook up to a tachometer and see if that's the case.
That being said, Verde gears feel too tall for normal driving, 4.1 gearing feels too short for a V6 on the freeway. Come to think of it, when I had 3.55 gearing, I recall cruising around 3K when I was commuting to school...I was driving around 70 mph! Now to go 70mph, my tach reads 3400rpm after I switched to a platinum box, what you should have!
1984 GTV-6 - 80K miles
Old 05-02-2008, 07:43 AM
fuel cut is at 6500 right? is so my tach is just about right. 3k rpm in 5th is about 63-65 mph and the redlined shift out of 2nd is just over 60. i love how tight the ratios are from 2nd - 5th but that 1-2 shift has an huge gap.
Old 05-02-2008, 09:58 AM
Gubi's Avatar
Yeah, but even with a 3.55 he should be at 5400 RPMs at 2nd in 60.
You're going to need to test your RPMs with a digital tachometer and your speedometer with a GPS unit to figure this one out.
1991 Spider
1987 Milano Gold
Old 05-02-2008, 10:46 AM
Grant's Avatar
hmm...3K = 63-65..
That sounds more like platinum gearing now, which is the most likely scenario. O well, hope you're enjoying the car!
Old 05-02-2008, 02:18 PM
Craig's Avatar
Craig Craig is offline
75/Milano manuals for all
Just not going to happen, 34mph @ 3000 rpm in second is the max with any standard gearset. You would have to be in fifth to get those speeds.
See the attached spreadsheet.
Craig,
1988 75 TS, 1989 164
Old 05-02-2008, 05:26 PM
not sure what Gubi and Craig are talking about but redline in 2nd (6250rpm) is around 60mph.
cruising in 5th at 3k is around 63-65
Old 05-02-2008, 05:52 PM
Gubi's Avatar
What I was talking about is that in your original post you weren't clear about the gear, and Craig and I read it as you reporting your RPMs in 2nd. In re-reading that I'm guessing you meant that the 2800 and 3000 RPM speeds were in 5th, correct?
Anyway, my original post with the MPH per RPM is valid and that's what you should go with.
1991 Spider
1987 Milano Gold
Old 05-02-2008, 06:08 PM
Craig's Avatar
Seems very clear that you were saying that you were doing 60mph at 2800rpm in 2nd.
Any surprise that I said "Just not going to happen".
And yes, at redline in 2nd a standard Platinum will be doing just over 60mph.
Craig,
Old 05-02-2008, 06:56 PM
looks like i was already one martini into the evening with my original post. yeah, i meant 5th gear for the 2800 rpm thing.
Old 05-03-2008, 09:30 AM
emerswf's Avatar
emerswf emerswf is offline
Junior Member
Nice job on the spreadsheet!
I'm building a 3.0 GTV6 and have a Verde at my disposal for all parts; this will help with my decision on what transaxle to run.
