I recently have the common problem of my clutch pedal going all the way to the floor. I have bled the clutch system several times using a large syringe to both push and pull fluid through the system. I don't get any bubbles, just fluid, so I know that isn't the problem. I also do not have any leaks in the system.
The only way my pedal works somewhat is if I top off the fluid reservoir beyond max. I know that somehow my clutch master is using the fluid reservoir as part of the compression process, which I know isn't right.
If I plug the pickup line with a bolt and clamp it down, I get a working clutch. Does anybody have a schematic of the Milano clutch master cylinder? It would be nice to see how the system works on paper. Does it have a check valve on the pickup line connection that can be replaced without having to pull the clutch master off? Is that part of the rebuild kit?
