Old 04-18-2008, 03:28 AM
75 GTA 75 GTA is offline
Send a message via MSN to 75 GTA
Brake upgrade
Hi
I allways thougth that my 75 had a problem about itīs braking.
The problem is not that is doesnīt have brake power (it does...it even blocks the wheels!) but instead I think it doesnīt "bite". It just wonīt bite until you put your foot down hard and then the wheels will block.
I tried to solve this problem by fitting a master cylinder recovery kit, braided hoses and dot 5.1. Got better but not enuff...damn!
So, what do you guys think I should do beside not braking at all
75 TS (modded) - 1993
166 2,4 JTD (modded) - 2001
Old 04-18-2008, 07:51 AM
Grant's Avatar
Grant Grant is offline
What pads are you using?
1984 GTV-6 - 80K miles
Old 04-18-2008, 07:54 AM
OMP pads.
Not the top of the tops but nad bad at all...
Old 04-18-2008, 07:58 AM
gtv6-3.0's Avatar
gtv6-3.0 gtv6-3.0 is offline
Unless you are on the track the OMP pads sound like they are too hard. On my Time Trial Milano I used stock for the street - thay worked fine - and changed to race metallics for the track.
Old 04-18-2008, 08:41 AM
Grant's Avatar
Hey, where do you time trial? What area are you from?
Old 04-18-2008, 09:01 AM
gtv6-3.0's Avatar
I have recently retired from Time Trials but have run at Lime Rock, Pocono, Watkins Glen and way back even at Bridgehampton. My prepped Milano was mortally wounded on night when a tree removed the passenger side so I installed all of it's running gear in a 1981 GTV6 with a blown engine I found in Texas
Old 04-18-2008, 09:29 AM
Grant's Avatar
How did the brakes hold up for you when you were racing? I think my rear brakes are getting too hot, but I could be fading at both ends of the car!
Old 04-18-2008, 09:33 AM
gtv6-3.0's Avatar
The rear brakes will fade!!!! Some people fabricate two sheetmetal scoops to direct air to the calipers which apparently works pretty well. I removed the two fog lights from the front, cut the backs off the housings and install a flex duct from there to the front calipers. Worked perfectly. Mind you the car is underbraked on the track especially if the engine is tweaked so you have to pay attention to how hot your brakes are getting
Old 04-18-2008, 01:56 PM
alfaspence's Avatar
alfaspence alfaspence is offline
a few people go for this mod (like i am) but requires machining and stuff
Spence
75 3.0 24v
Old 04-18-2008, 02:09 PM
Grant's Avatar
That's pretty sweet. I've had a moderate brake upgrade (FD calipers, Supra Turbo rotors) for the front, but I haven't installed it yet because the rear brakes seem like the weak link! SZ upgrade is expensive now too.
Old 04-19-2008, 07:26 AM
fast-alfa75's Avatar
fast-alfa75 fast-alfa75 is offline
Check out the brake package by Group 2 Motorsports. I have been running it on my Milano for two years now, and it is a total solution.
Old 04-19-2008, 09:39 AM
Where can I find Group 2 motorsport?
Do you have their site url?
Thanks in advance.
Old 04-20-2008, 06:02 AM
kredden's Avatar
kredden kredden is offline
Group 2 Motorsports
Kevin
86 Spider Veloce
87 Verde
Milano registry custodian(www.alfamilano.com)
  #14 (permalink)
Old 04-21-2008, 12:40 AM
Thanks, Iīll take a look
  #15 (permalink)
Old 04-21-2008, 05:54 PM
75evo 75evo is offline
I have Porsche (Brembo) brakes in the front, no problems since then, no bleeding needed at the track.
If you can grab the older 156/147 GTA calipers (smaller type) and a bigger rotor, that should more than adequate for the 75.
My setup with 2-piece rotors (aluminum hat) cost me $1100+ I think. I don't have much problems in the rear, although eventually I may get vented rears. Only problem is, space is tight back there and you can barely fit a 2.5" exhaust pipe even with the non-vented discs.
1987 75 1.6ie
Mods so far: 185/65/14 Nankang HR Tires
