Old 04-15-2008, 01:57 PM
cmilano's Avatar
cmilano cmilano is offline
cv boot replacement
how do u pull apart the rear inner cv joint to get the boot off?
Old 04-15-2008, 05:30 PM
86spider 86spider is offline
cv joint removal
once you have removed the half shaft, clean the grease out and on the end of the shaft is a clip. remove the clip, be careful not to let it sproing itself across the room never to be found again. the cv joint will slide off the end of the shaft.
Wayne
Old 04-15-2008, 06:29 PM
Graham D's Avatar
Graham D Graham D is offline
You must remove the end metal cover to get to the spring clip. Grind a blunt end on a small chisel or use a blade screwdriver and tap it off with a hammer.
Old 04-15-2008, 07:06 PM
AR4me's Avatar
AR4me AR4me is offline
Buy the manual or download it (for free) from Craig's site. You need a press (at least I did for all the ones I have done).
Jes
87 Milano 3.7 24v - race car
Old 04-15-2008, 11:19 PM
NMMilano NMMilano is offline
I just did mine and got lucky, I did not need a press. After removing the circlip I tapped the CV with a brass hammer and they slid off the axle shaft.
The boots now available are really too small and it takes alot of strength and patience to get them to fit!
At least they wont leak.
87 Milano Platinum
70 Fulvia 1.3 Rally S
Old 04-16-2008, 04:46 AM
scott.venables's Avatar
scott.venables scott.venables is offline
Send a message via MSN to scott.venables
Yeah you may or may not need a press. There should be a really strong conical spring washer between a lip on the axle and the CV centre. You can get the clip out without compressing the washer, but it will be impossible to get it back in. When mine were apart, half had the washer half didn't.
Scott
Old 04-16-2008, 10:49 AM
cmilano's Avatar
thanks for the help. once i get the boots fitted and shafts bolted back in place all thats left is new tires and rims, put timing belt covers back on and then make my side out exhaust system and she will be ripping.
