#31 (permalink)
Old 12-06-2004, 08:18 PM
PSk PSk is offline
Originally Posted by junglejustice
Nobody is Selling a kit here...
This is not a kit. The calipers come from Praggia in South Africa. The floating hat rotors come from a source in California. The pads are Ferodo from a large Mercedes van. We are custom making the brackets....
My bad
The guys who have done these conversions on Milano/GTV6 and raced them competitively MAINTAIN that you GAIN stability at higher speeds with the rears moved outboard - nobody suggested anything about weight.... If anything, gaining unsprung weight is a negative, but so is boiling tranny oil. You can argue with THEM if you would like, I won't.
Yeah I don't get the stability comment ... . I also do not understand the boiling of the gearbox oil ... surely cooling ducts to the rear discs would solve that?
I drill my brakes so hard sometimes that one time I bent the backing plate off of one of the front pads and it curled the plate back away from the pad surface to where the piston carved a circle into the backing plate! (And the wheel would still not lock up at that speed/nose dive!)
Wow, never heard of that before ...
I disagree with your "simple balance bar solution" as the only thing needed Mr. Feet on the ground....
Sorry miscommunication. What I meant is if you are going to all this expense and trouble, then do not short cut with crappy proportioning valves, but go the whole hog and install a brake balance bar pedal arrangement. That is what I meant. Makes no sense having all the clever stuff at the wheels when you do not have proper balance control ... refering to this comment:
Originally Posted by BigSwede
Just throw the proportioning valve away and buy an adjustable from Tilton or Wilwood, I got one and it is very good. Recommended.
The 2 piston caliper Brembos on a Milano Verde are crap for many of us here... (This must be the reason all of the "school kids here are sitting around" (not just talking about it) but actually spending good money to change them out!?
At one third the price of Brembo, it's worth trying.
Fair enough ... I guess you do not have to worry about the handbrake then?
EDIT: Just read this ...
The smallest calliper from Praggia is the 4 Pot and it will run a minimum 265mm disc, with or without a handbrake....
Thus handbrake solved!
ps: This comment
While mine will not be an IMSA car, it will be a dedicated track car ...
Makes all this effort worth while ... but I can't see it being worth if for an ocassional track car myself ... but that is just my opinion. What ever floats your boat I guess.
  #32 (permalink)
Old 08-23-2006, 12:44 AM
inhistoryclass's Avatar
inhistoryclass inhistoryclass is offline
what size are the stock milano brakes up front?
  #33 (permalink)
Old 08-23-2006, 01:21 AM
Rookie ROX's Avatar
Rookie ROX Rookie ROX is offline
Rotors are 268mm diameter and 22mm wide. Calipers are 2 pot Brembo items for most of the models - though in true Alfa fashion, some came with different calipers (ATE?).
ROCK ON
R~R
  #34 (permalink)
Old 08-26-2006, 02:18 PM
are there any good pictures of the conversion? id like to see how they made the bracket.
my cars
95 LS - 5 speed
87 milano silver - 5 speed
  #35 (permalink)
Old 10-30-2007, 03:10 PM
ToonRboy's Avatar
ToonRboy ToonRboy is offline
Me too - once I had a deDion hypotenuse tear off (mostly) at the rear where it meets the rear (big) tube (corrosion started from a pinhole rust spot if you can believe it). Anyhow, when I sorted a replacement and got to check it out up close (real close). I was surprised to see how thin the walls are and how light the deDion unit is. Hell, I was thinking of fitting a couple of bracing triangles at the wheel bearing housings as a precautionary upgrade..!
I would think you'd have to design a whole billet collar or something to mount the calipers to. I certainly wouldn't weld the mounts (ears) to the deDion tube directly (and expect it to hold/last).
  #36 (permalink)
Old 11-03-2007, 11:07 AM
junglejustice's Avatar
junglejustice junglejustice is online now
Geez this is an old thread! (My apologies to Barry again for all of the catty-ness back then - that whole thing was stupid... )
Any way, been done/being done plenty - welded right to the DeDion like that. Raced like that without problems for years on several cars in SA and in other places I'm sure... (...and the sky hasn't fallen yet... )
Here are some shots!
I'm sure that some or other billet modified setup there (a-la IMSA cars) with adjustable camber and toe would be awesome back there! (Send Bianci & Kopp the 5K Euro check for the carbon fiber DeDion unit while you're at it...) This works (but our new AP setups will have a cleaner billet aluminium bracket on steel welded bracket-arrangement when they finally come in...)
Full-Race 3.7 Litre 24v Milano; Street/Track 3.0 Litre 24v Milano Verde; 2.0 TS '73 GTV; 6-speed 3.45 litre 24v Street 164 LS/Super; '06 Scion XB - Runs!
  #37 (permalink)
Old 11-03-2007, 11:39 AM
Del Del is offline
The primary reason the rear brakes were designed for the inboard location in the Alfetta/Milano/Gtv6 series was to reduce the "unsprung weight" parts of the rear suspension, ie, the lighter the moving parts of the suspension, the quicker the suspension can react to forced movements. This means the tire can remain in contact with the pavement just that little bit longer. A good thing, and by the way, copied by other makes. Remember the rear axle hop of the older "solid" rear axle Alfa's when a bump was encountered in a hard fast turn? These solid rear axles were the worst examples of high unsprung weight, although they were acknowledged to be the better examples of this type of suspension.
The obvious drawbacks of inboard brakes are potentially less cooling, and more limited access to the brake assy. Your choice. Since the rear brakes work much less than the fronts, I like the inboard setup, for it's quicker response over bumps and uneven pavement in turns, over my previous older Alfas.
Going to larger rear brakes without matching that size change for the front can be overkill since you can use only so much of the rear braking potential while maintaining the proper front/rear braking ratio for directional stability. The only advantage would be that the brakes would remain pretty cool compared to the harder working fronts; however, brake pads change their friction coefficient with temp and would have to be picked carefully to reflect this difference in braking temps front to rear. Ideally you would want to maintain the same approximate braking temp front to rear to reduce this unwanted variable.
p.s. looking at the pix of the welded bracket of the brakes shown above, I might question the limited strength and torsional stability of the bracket design as welded to the cross tube. I also might question the use of aluminum for any bracketry in such an application.
Del
Seattle
89 Milano
91 164S
94 164LS (Q)
72 Morgan 27
  #38 (permalink)
Old 11-03-2007, 11:53 AM
Yeah, no - there's a whole entire other thread out there, that is sort of a missing link/gap to this one - part of the problem when reviving something this old...
Our entire system (the new setups coming) was re-designed mathematically (at least in theory - on paper - as close as possible) and proportionally engineered - with proper dual master cylinder sizing (front versus rear) and then also taking in to consideration such aspects as the friction coefficient of the selected pad compounds, total swept area of each disc, the manufacturer's duty-cycle/rate of cooling specifications for the selected discs, total surface areas of pads (versus discs), piston-diameters, vehicle weight and load-weight centers, tire and wheel sizes, brake pedal-ratios - on and on...
In addition we are installing Tilton adjustable bias bars and remote adjusters to be able to fine-tune the setups!
Del - buzz me - I may have the rim for you - 425.941.4747.
  #39 (permalink)
Old 11-03-2007, 11:55 AM
ToonRboy's Avatar
Hey, you gotta hand it to those SA guys, they're friggin' crazy! The nose and the bearing housings of the tube looked like they were cast steel if I remember correctly. Perhaps they are a rough forge. I wouldn't weld to cast steel. The brackets looks simple enough & there is sufficient weld. If it holds, it holds. More power...
Are those 6 or 8 puck calipers in the rear? ;p
Makes you wonder what's up front...
  #40 (permalink)
Old 11-03-2007, 12:46 PM
Today - 4-piston rears and 8 pot fronts...
The new setups are GIANT 4-piston/4piston APs...
  #41 (permalink)
Old 11-03-2007, 11:11 PM
5yearplan's Avatar
Thats not 1/8" is it? looks a little thin for brakes. But those welds are definitely solid. Good penetration for cast steel. But the money's in the prep work.
[SIGPIC][/SIGPIC]
You should buy my stuff: http://www.alfabb.com/bb/forums/showthread.php?t=44309
Restore and Engine Conversion:http://www.alfabb.com/bb/forums/showthread.php?t=46024
