Old 04-03-2008, 02:54 PM
Del Del is offline
Milano/75 front turn signal lens compatability
Does any one know whether or not the Euro 75 front turn signal lenses with the housing two mounting screw holes, as compared to the Milano three hole housing can be used in the US Milano fender?
Two issues: the lower mounting screw location can be made to work by drilling a new hole in the correct location in the mounting bracket which comes off the headlight frame. However, I don't know if the upper single screw location is the same for both lenses. Also, the white plastic housing for the 75 lens is shaped just a little different than the US version. Will the 75 housing fit in the fender of the Milano?
Appreciate any info.
Del
Seattle
89 Milano
91 164S
94 164LS (Q)
72 Morgan 27
Old 04-03-2008, 03:15 PM
JoeCab's Avatar
JoeCab JoeCab is offline
Yes, with the modification that you've already described they will fit fine.
Old 04-05-2008, 04:48 PM
fast-alfa75's Avatar
fast-alfa75 fast-alfa75 is offline
I agree, no issue with final fit, just have to drill those holes. Installed them on mine, looks great! Thanks Centerline!
Old 07-24-2008, 08:44 AM
ALFA-75-MAN's Avatar
ALFA-75-MAN ALFA-75-MAN is offline
Well my first mistake was to cut those screw plastic nipples for lack of a better term but not fitting exactly the way Id like. So I will re drill small holes but I hope I have enough material to screw into. Also I believe the buld housing rubs ect...Adjustng head light to make this fit isn't a bright idea either.
I'm almost tempted to glue the f---n thing in! Leave it to Alfa to have different lights for two of the same cars. What the f---k is that all about.
1988 Alfa Milano Verde
