03-28-2008, 01:11 AM
JJ has fitted the later motor into a milano, but yes, it wasn't plain sailing
Spence
75 3.0 24v
03-28-2008, 10:39 AM
i didn't say that it cann't be done.... just a lot of hassles you don't get with a 164 24v engine.
03-29-2008, 02:27 AM
Originally Posted by EVO 75
hey nizam, that guys is from sydney here in australia. its a standard 3.0 24v from a 164. he's done all the work himself
Mate are you able to post a few more pics of this guys car or better still tell him about the board and get him to sign up and he can tell us all himself.
03-29-2008, 04:35 AM
Sorry, i wasn't saying you were just for illistration saying it was feasable, but as you say, plenty of work and not for the faint hearted...
but lets face it, the 164 motor is neither cheap or easy to install either
Spence
75 3.0 24v
03-30-2008, 12:30 AM
seeing you live in sydney, you should know about interspec...? try dropping a line to bulli, he knows the owner of the car. bulli does alot of stuff for alfas, so he's got all the hook ups with owners and so on. i think it was bulli@interspec.com.au or you could just try his website and contact him through that interspec.com.au
04-03-2008, 09:30 AM
The 3.2 giuliettaevo is talking about is the new (GM block) V6 introduced since 2005 in the 159, and Brera. The 3.2 GTA from the 147 is still basically the 164 24v heads on the original Busso designed block methinks.
That intake pictured earlier is the best package I've ever seen - simply marvelous work and innovation! On the technical side though, that's a LOT of plenum volume. Since the runners are spliced, I suppose you could open them sequentially to maintain low rpm vacuum (and torque). One way is to use a split runner design, one short, one long, for each cylinder - Like Yamaha did on the Ford SHO. This provides the best of both worlds.
04-09-2008, 09:24 AM
I think you can use your 75 v6 flywheel on the 3.2 gta engine.
The front crank cover from a 164 24V (or 12V ) can be used, some grinding to make it fit and get the 3.2 to work with a 164 24V MMS or other aftermarket possibilities.
04-09-2008, 10:36 PM
Attachment 97518
My bad i thought we were talking about the earlier 3.2 (147 & 156 type)
I knew Alfa were using a GM motor but was lead to believe it was the diesels
Don't like the intake system on SHO! My GM (Vauxhall Vectra) 2.5 V6 employs a design very much like it, great for torque, and low down grunt, but it sure does NOT like to rev to the red line
Spence
75 3.0 24v
04-09-2008, 10:42 PM
I have 3 off different engines! And they are all different
Some will grind, some won't, some need extensive drilling and tapping too! And thats if you are using a crank trigger (mounts were moved)
(iam not flaming, just for info purposes)
Spence
75 3.0 24v
04-10-2008, 12:28 PM
I'm using the front cover of an early (1990) 164 12V for my 24V.
BTW Spence, will this be a stock 24V or with some added goodies engine wise?
1987 75 1.6ie
Mods so far: 185/65/14 Nankang HR Tires
04-10-2008, 01:17 PM
i was not talking about the new gm engine!!!
engine is different from 164 engine.
04-10-2008, 01:27 PM
check this topic for the differnces... 3.0 from 166 is the same newer type of engine as the 3.2 GTA.
ALFAGTV6.COM ~ View topic - 166 24v into 116 GTV
04-11-2008, 02:24 AM
Phew i got scared there
Spence
75 3.0 24v
04-11-2008, 02:31 AM
i knew the coolant system was different, but why the cut and shut on the stat housing?
you bin the later plastic impeller type pump in favour of the older metal type (its proven more reliable, its a common mod done by several GTA owners) easy! then the gtv/milano stat housing complete fits straight on!
BTW i didn't read whole article, so i don't know what else there is
Spence
75 3.0 24v
