Old 08-14-2004, 12:44 AM
Grant's Avatar
Grant Grant is offline
Polyurethane Bushings
Hey Guys!
Earlier I installed urethane caster bar bushings. This got me less slop in the steering, always a good thing. If your caster bar pads are shot, replace them...not very hard.
So onto my question:
Who here is driving their cars with a majority of their rear suspension coupled with urethane bushings? Watts linkage, swaybar, shock mounts etc.
Do you notice excessive road vibrations? Squeaking?
-grant
1984 GTV-6 - 80K miles
Old 08-14-2004, 12:56 AM
Mezevenf's Avatar
Mezevenf Mezevenf is offline
Send a message via ICQ to Mezevenf Send a message via AIM to Mezevenf Send a message via MSN to Mezevenf Send a message via Yahoo to Mezevenf Send a message via Skype™ to Mezevenf
Yes, yes I do. The squeaking isnt excessive but its there sometimes. The road where I live are pretty rough and I'm on Koni Yellows, so it really is a very rough ride, but thats expected . I wonder what lower profile tyres would be like...
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
NightSpec
Old 08-14-2004, 01:07 AM
fraz's Avatar
fraz fraz is offline
I was thinking about getting some of the caster bushings. Did you notice any more noise or better steering response?
I have the deDion center in poly and it really stiffened the action quite a bit. I think I liked the give of the rubber a little better. I was not thinking of doing any other rears except for maybe the Watts bushings. Not to mention I have already decided that if I ever build a "track only" car I will likely make aluminum bushings for most of the car.
Old 08-15-2004, 08:22 AM
eminence's Avatar
eminence eminence is offline
Send a message via MSN to eminence
Originally Posted by Grant
Hey Guys!
-grant
Don't do the shock mounts in poly as it will reduce the shocks life considerably. Because it doesn't flex like the rubber ones it trys to bend the shocker instead.
Old 08-15-2004, 06:45 PM
Grant's Avatar
Thanx for the info on the shock mount.
Oddly enough, the caster pads didn't actually increase road feel any noticeable amount. The slop i was feeling before in the dead zone completely went away though. That was worth the time installing for sure.
So I suppose I won't do ALL of the rear suspension then.
-grant
Old 08-16-2004, 01:08 PM
toeside's Avatar
toeside toeside is offline
Send a message via AIM to toeside
Grant,
I'm quite interested in this mod as quite a few enthusiasts applaud the results. In searching for information, I ran across a web page by Larry Dickman that describes a mod to replace the caster rod end assembly with the ball and socket joint from the series 105 - 155.
I'm wondering if you also considered this, or if you may be considering it for the future.
Also, where did you source the parts? Performatek?
Thanks!
-- '87 Milano 3.0 (the "NanoCar" a.k.a "Money Pit 2" )
-- '85 GTV6 2.5 ("Money Pit 1")
-- '86 Spider Veloce (ran off to a better home )
Old 08-16-2004, 07:49 PM
Grant's Avatar
I actually bought my parts at Centerline. IAP didn't have them in stock, otherwise that was my first choice. There was no documentation on installation but none was really necessary.
I have considered using the ball joint assembly. I have 2 milanos that needed the caster pads replaced so I thought i would try poly urethane on one car and the ball joint on the other once i had some more money and time.
In practice though, I found the urethane joints to be all I needed. The actual steering feel is barely improved, but like i have said earlier, the main benefit is it got rid of the play i was feeling in the steering. More vibration is noticeable in the cockpit which I don't mind (makes it feel more connected you know?) but I can imagine the ball joint to be excessive. And what if the ball joint starts to squeek or rattle or, even worse, rust over time?
After all this I think im going to use urethane on the other car.
-grant
Old 08-17-2004, 04:46 AM
toeside's Avatar
Thanks for the reply... exactly the kind of information I was looking for...
Called IAP and they have their bushing kit back in stock...
Old 08-17-2004, 05:09 AM
If any of you are interested I have a decent article on installing poly bushings at http://www.oldebottles.com/italiancarspage6.htm. I suggest poly bushings over heim (rose) joints for a street car, you get 90% of the performance benifit without the drawbacks
Old 08-17-2004, 08:44 AM
toeside's Avatar
Greg,
Kudos on a beautifully detailed page ... it's a downright luxury to know exactly the procedure... many thanks! Good story about your dad "stealing" the Milano back to Nebraska too
