  #31 (permalink)
Old 04-02-2008, 07:14 AM
alfaspence's Avatar
alfaspence alfaspence is offline
Hey Nizam! just for you i took some more pics this morning!!
Spence
75 3.0 24v
  #32 (permalink)
Old 04-02-2008, 07:17 AM
alfaspence's Avatar
and one more
Spence
75 3.0 24v
  #33 (permalink)
Old 04-02-2008, 09:58 AM
nizam's Avatar
nizam nizam is offline
Wot??!? No Air-Con? You'll be sweatin' yer balls off on those hot Ipswich summer nights bro!
Nice work. You've inspired me to take some pics of my own project. I'll have to start my own thread though Keep the pics coming! Would love to see your intake, and exhaust manifolds.
  #34 (permalink)
Old 04-02-2008, 10:33 AM
Grant's Avatar
Grant Grant is offline
I think you might run into a bit of trouble mounting that rear sway bar..
It looks like you've got the retaining brackets facing the chassis, not facing the tranny (the C looking pieces of metal). I had trouble mounting my sway bar and had to bust out the cutting wheel to make it fit.
1984 GTV-6 - 80K miles
  #35 (permalink)
Old 04-02-2008, 10:52 AM
alfaspence's Avatar
now you,ve torn it i can't remember which way they face now...
Going to look later when i get home
Spence
75 3.0 24v
  #36 (permalink)
Old 04-02-2008, 10:57 AM
alfaspence's Avatar
got to be kidding me man this is the UK! What do i want air con for (the car never had it anyway) besides, i have 4 electric windows like
Good show! glad ive inspired someone
As yet, i still have no intake or exhaust manifolds (or anything that'll fit anyway) Going for some tuned length headers tho
Spence
75 3.0 24v
  #37 (permalink)
Old 04-02-2008, 06:47 PM
mike maserati's Avatar
mike maserati mike maserati is offline
I now that i have evo but not imsa kit. total different the kit you getting made by EMC in holland. there same guys that make for mercedes-benz. It a DTM body kit. Imsa 75 turbo are real production car tag 200 a year where made for racing rules. There is a Widebody for sale in holland if you got 28,000 check it out( Single Seaters, Rally Cars, Touring Cars, Sports Cars, Historic Cars and Road Cars for sale). My friend in Italy telling me to go get that $37,000 plus shipping for me Canadian. Regardless your cars going to look sick at they end. If you ever seen one up close like i have it will leave you speechless.
  #38 (permalink)
Old 04-03-2008, 09:31 AM
alfaspence's Avatar
believe me, if i had 28k id buy it! to hell with the fact its made from unobtainium!
Speechless? thats what iam hoping for
Spence
75 3.0 24v
  #39 (permalink)
Old 04-03-2008, 11:46 AM
daz's Avatar
daz daz is offline
hi mate Im in the uk and have a gtv6 which im changing the engine I have a 3.0 75 engine ready to install and i also have a spare 164 24 valve engine which i will be modifying over the next few months
I notice you have a 24valve engine in your car and was wondering where you got your 4mm flywheel spacer
  #40 (permalink)
Old 04-03-2008, 11:47 AM
daz's Avatar
daz daz is offline
btw is that a 164 brake servo
  #41 (permalink)
Old 04-03-2008, 12:56 PM
alfaspence's Avatar
4mm spacer not applicable to the 75 unfortunatly, only the Gtv's as far as i know... as to who makes them iam not sure (anybody else please chime in??!!)
not straight forward as the bolt holes have uneven spacing!
The Alfa V6 is also externally balanced, thats another issue that you need to address depending which motor you are using (front pulleys etc)
The servo is a Bendix from a 1990 T/s 75 , the master is ATE from a BMW E30
Spence
75 3.0 24v
  #42 (permalink)
Old 04-03-2008, 03:49 PM
daz's Avatar
daz daz is offline
In most of the forums on alfa bb and gtv6.com it states the 75 and gtv6 engines are a straight forward swap as they are the same block just bigger bore and stroke when upgrading from 2.5 to 3.0
The 164 12 and 24valve engines are a slightly shorter block (4mm) and in nearly all the discussions on converting from a fwd 3.0 to a rwd 3.0 it mentions the need for a flywheel spacer (amongst a few other minor alterations)
I assume the 24 valve engine in your 75 came from a 164 and if it is are you saying the spacer wasnt needed?
  #43 (permalink)
Old 04-04-2008, 08:00 AM
alfaspence's Avatar
that 24 valver is a 164 unit... not sure what the deal is here but, the blocks are the same length, and the crank measures the same out as my 3ltr 12v 75 unit.
So spacer? not on my car there won't be!! only the bolts need be longer for the 75 flywheel (fine thread too)
And should any issues arise, my prop has a splined coupling at the front end! (std)
Spence
75 3.0 24v
  #44 (permalink)
Old 04-04-2008, 12:12 PM
daz's Avatar
daz daz is offline
The splined front prop had crossed my mind.I think the reason everyone else seems to use the spacer is because of the 4mm difference ( or so they say) between the two engines but as you have a 164 engine in your car then perhaps the need for a spacer is not neccessry as the splines on the prop could easily accomodate 4mm
Im in no way an expert and you have obviosly successfully fitted the 24valve so I would gladly take your advice as i would like to eventually nfit a 24valve in my gtv
BTW did you know the only difference between the 24valve 210bhp super and the 24valve 230bhp cloverleaf engine is the intakes
  #45 (permalink)
Old 04-04-2008, 01:40 PM
alfaspence's Avatar
Oh yes! mine got upgraded to the larger chrome runners whilst i was still smoking around in the 164
Someone then told me that theres an ecu tweek also to acheive that 230bhp, not sure how true that is tho.
They are the same runners on the 164 QV, and the 3.2 GTA units (for info purposes)
Spence
75 3.0 24v
