Old 02-10-2008, 07:11 AM
Razz Razz is offline
Help With Drive Shaft
Hi,
Need to know where I can get this bearing at the tip of the drive shaft. Or is there a mod for this. This is the end side that goes in the flywheel motor side.
Thank you for help.
Razz
86 Milano platinum (Getting There)
83 Autobianchi A112 Junior (with Abarth Engine) For Sale
Old 02-10-2008, 11:42 AM
SamW's Avatar
SamW SamW is offline
Looks like you are missing a good bit there, the bearing is long, maybe an inch and a half and has a spring inside. Once I get home I can sanp a picture of what it is supposed to look like.
'86 GTV6 - No Name
'89 Spider Quad
'89 RC30
Old 02-10-2008, 03:17 PM
Thank you Sam, I would really appreciate it.
Razz
Old 02-11-2008, 11:31 AM
RAGs's Avatar
RAGs RAGs is offline
Alfisti
Recently got one ...
...from Ed at DiFatta. A tad pricey ($40+) given what you get but SamW is right that something is missing.
This is the portion of the shaft inserted into the flywheel and the assembly helps center the driveshaft. To be precise, chances are the bushing itself might still be embedded in the flywheel! (Along with the spring and snap-in locking washer) Make sure these are not still in the flywheel before reassembly or you will not be able to reinstall the shaft!!
The concave bit on the end actually pivots within the cylindrical bushing compensating for engine movement in relation to the driveshaft. The assembly needs to be well lubed as after some time the pressure of the spring could force the pivot tip to ware through the bushing.
Tip: You don’t need a press to install but heat the new tip and coat with oil before assembly. Getting the snap ring in can be fun.
Good luck.
Red '88 Milano Verde - When you just gotta to have 4 doors...
Black '86 GTV-6 - The one that got it started and needs to be re-started...
Yellow (soon to be) '67 Duetto - middle of delayed restoration...
--- Honorable Mention ---
Burgandy '94 Volvo 850 Turbo - Groceries ...
Emerald '90 VW Corrado - The Backup ...
Brown '71 C10 Stepside w/ a 350ci and 3 on the column
Old 02-11-2008, 05:43 PM
SamW's Avatar
Pictures
Sorry, it has been a rough couple of days. Anyway, here is a picture of how the end should look, this is off a 3.0, but I am pretty sure the 2.5 looks the same. There is a snap ring holding a spring inside, can't really see that in the photos.
'86 GTV6 - No Name
'89 Spider Quad
'89 RC30
Old 02-11-2008, 06:04 PM
Thank you SamW & RAGs for your help.
Razz
