Old 02-07-2008, 02:50 PM
lgbalfa's Avatar
lgbalfa lgbalfa is offline
Send a message via AIM to lgbalfa Send a message via Yahoo to lgbalfa Send a message via Skype™ to lgbalfa
milano automatic ?
did they make the milano in an automatic?
if so - can anyone post a pic of the interior?
thanks
1992 alfa romeo spider veloce, 17k miles
2000 saab 9-3 coupe, 19k miles
Old 02-07-2008, 03:34 PM
Zunige's Avatar
Zunige Zunige is offline
In the Spiders' nest...
Yes, some Milanos with the 2.5 liter engine did come with an automatic transmission. There were four Milano editions: Silver, Gold, Platinum and Verde. The Verde was the "quadrifoglio" edition, with the larger 3 liter engine, and only came in a standard shift.
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Old 02-07-2008, 04:00 PM
rcess's Avatar
rcess rcess is offline
In '88/'89, the Milano Platinum came only with an automatic, while for the Milano Gold the automatic was an option. Prior to '88, there was only a stick.
Bob Cess
'59 Giulietta Sprint
'60 Giulietta Berlina
'62 Giulietta Spider
'69 Spider Veloce
Old 02-07-2008, 04:02 PM
yiminlu's Avatar
yiminlu yiminlu is offline
thanks
Mine
Old 02-07-2008, 04:03 PM
lgbalfa's Avatar
Originally Posted by yiminlu View Post
Mine
thanks.
looks like the same type of shifter in my spider automatic.
Old 02-08-2008, 08:10 AM
rjv125 rjv125 is offline
Why are you looking for a picture of the Milano automatic interior?
I bought the red one listed on ebay this summer for $532. The interior is basically the same as a manual Milano except the automatic shifter. Car had 80,000, ususal rear fender rust, and a little rust underneath. Also, the corrugated hose from the airfilter box to the plenum had a hole in it, the exhaust pipes were broken right after the cat converter, needed a rear exhaust, the rear brakes needed a slight adjustment, and the heater fan doesn't work. I parted out a Platinum and got all of my parts from that car except the new rear exhaust. Its a good daily driver, but a real slug. It only has a 3 speed trans. I wish I could put a four speed in to possibly get a shorter first gear and and a longer fourth gear for highway.
Old 02-08-2008, 09:35 AM
lgbalfa's Avatar
i did not know if they made the car in an automatic and was curious to see what the interior looked like since the dash on a spider is different for both the manual / automatic.
Old 02-08-2008, 07:45 PM
JoeCab's Avatar
JoeCab JoeCab is offline
This is correct; although I'm not sure there were many '89 Platinums, nor any '89 Silvers (please correct me if I'm wrong here).
Let's get back to the specs. of the automatic. It was a ZF 3-speed with a 3.15:1 final drive. It had an open (non-LSD) differential. The ZF transmission itself was used by many other cars of the era, although the casing was unique to the Alfa.
All of the automatic cars also had a self-leveling rear suspension, which used the power steering hydraulic circuit to raise and lower the rear of the car depending on load. You are very unlikely to find one of these self leveling suspensions in working condition - most have been replaced by the standard rear suspension from a manual transmission car by this point.
Old 02-08-2008, 08:07 PM
sh0rtlife's Avatar
sh0rtlife sh0rtlife is offline
are you sure about the auto's all being open diff?..ive seen more than a handfull of them for sale and all have been LSD
[SIGPIC][/SIGPIC]
Old 02-08-2008, 08:57 PM
JoeCab's Avatar
Alfa never listed the auto transaxles as having LSD as either standard or an option.
How do you know the ones you saw for sale were LSD without opening up the case?
Old 02-08-2008, 10:44 PM
Rookie ROX's Avatar
Rookie ROX Rookie ROX is offline
I don't know about Milanos, but I was under the impression all automatic 75s had an LSD as standard. I know our '89 75 Auto has an LSD fitted.
rjv125 - I remember reading that Alfa intended on putting a 4 speed unit from a BMW (from memory) in when they made the car, however they discovered that the box was too big and would require intrusion into the cabin, reducing overall space and simplicity of model variants, so they settled for the 3sp ZF unit.
ROCK ON
R~R
Old 02-09-2008, 08:21 AM
Hmmmm, very interesting. We all know the engine is fantastic, I just wish the gearing was better.
The hydralic rear suspension was taken out of my car and replaced with some stock shocks, but everything is still in place if I ever wanted to put it back. Probably really expensive.
We do have a slight bottoming out problem in the front actually with speed bumps. Was the ride height any different on these cars or did the previous owner mess with the torsion bars. Does anyone know what the ride height should be?
Old 02-09-2008, 04:59 PM
lgbalfa's Avatar
are the specs for the milano automatic the same as on my spider ?
