Old 02-03-2008, 01:49 PM
Tamariini Tamariini is offline
Milano 3.0 V6 propshaft question.
Is it similar with the one in GTV6? same length and guibos?
So does it fit to Milano 3.0 flywheel?
Thanks.
-GTV 3.0 V6TB 12V-
-75 3.0 V6TB with megasquirt (soon...)-
Old 02-03-2008, 04:23 PM
Duk Duk is online now
Guibo's would be a yes.
As for length, I'd say maybe
If you can find the wheel base figures for both cars and they are the same, then you'd be on a winner
Alfa 75 Potenziata
Supercharged AW11 MR2 (soon to be twincharged)
RB20DET S13 Silvia
Old 02-03-2008, 08:19 PM
Alfar7's Avatar
Alfar7 Alfar7 is offline
Richard Jemison
GTV6/Milano driveshaft
No milano longer in two sections.
Richard Jemison
RJR Racing
http://scuderiagiallo.com
Old 02-04-2008, 01:48 AM
alfa753ltr alfa753ltr is offline
Guibo`s and centre bearing/mount the same. Buy from I.A.P.
Old 02-04-2008, 08:07 AM
alfaspence's Avatar
alfaspence alfaspence is offline
apparently different centre bearing sizes too
Spence
75 3.0 24v
Old 02-04-2008, 10:27 PM
Have just bought from I.A.P. for my milano 3ltr 1992. The part no`s for the center bearing and mount were the same and they all fitted perfectly.The year model does not go so high as 1992,(only to1987 or 8) but i can assure you they fit.
Old 02-05-2008, 07:17 AM
alfaspence's Avatar
milano's are probably all the same, but the 2ltr has a smaller diameter propshaft, hence the different centre bearings etc
Spence
75 3.0 24v
Old 02-05-2008, 10:54 AM
My problem is that i have 3.0 V6 engine and 2.0TS gearbox and i have to connect them together some way.
The thing is it's almost impossible to find Milano propshaft here so i have to improvise. The propshafts that i have found are the one from TS, one from GTV6 and one from GTV with 2.0 carb engine.
Any ideas how can i build a propshaft to 75 V6 from those components mentioned above? Or is it impossible without cut'nweld
-GTV 3.0 V6TB 12V-
Old 02-05-2008, 12:54 PM
alfaspence's Avatar
easiest way would be to use a complete V6 prop, and to use a V6 clutch nose assy
Spence
75 3.0 24v
Old 02-05-2008, 01:26 PM
Yes it definitely would, but they are not available here. I've been searching one for quite a long time...
-GTV 3.0 V6TB 12V-
Old 02-05-2008, 01:56 PM
alfaspence's Avatar
where are you based? theres one on ebay (in the uk) as we speak!
if you do cut and shut the prop, please get it done proffessionally! correct conditions permitting, it WILL come into the cabin if it fails
Spence
75 3.0 24v
Old 02-05-2008, 09:55 PM
I'm in finland. That auction in ebay is pickup only. Doesn't want to deliver it here
-GTV 3.0 V6TB 12V-
Old 02-06-2008, 08:30 AM
alfaspence's Avatar
hmmm thats a bit awkward of them.... i'd ship you my spare if i didn't need it! blimey ive sent stuff to Finland before (its no big deal)
try Wayne at EMC racing iam sure he'll be able to fix you up with the neccessary bits...
EMC Racing Home
Spence
75 3.0 24v
  #14 (permalink)
Old 02-06-2008, 09:43 AM
EMC Racing Home
Thanks!
I'll contact them
-GTV 3.0 V6TB 12V-
  #15 (permalink)
Old 02-06-2008, 07:01 PM
Todd Todd is offline
It is possible to remove and replace the yolk( flange) for the rear flex disk at the clutch. I have a 3 liter clutch with a 2.5 box, running a alfetta driveline. On a 2 liter. Maybe this can help you. I just removed the 3 liter yolk, and installed the 2 liter yolk.............same size clutch shaft...........
Husqvarna 2002 CR 250 motocross(made in italy)
Alfetta sedan 1977 modified
87 Milano Verde low miles
