Hi,
I recently decided to try and do a little upgrade to my fog lights by doing an LED conversion. I had just replaced the fog light bulbs but still wanted to try and get a bit more out of them. Some of the benefits are that they will last practically for ever, they draw less current then the stock bulbs, and i think they're cool
The only supplies needed were some plexiglass/lexan from the local homedepot, LEDs and Resistors. I think i ended up using about 48 LEDs per fog light, since they are only about 28 cents each that comes to about $13.50. You need the resistors to have the proper current flowing through them. I have more pics and can post detailed instructions on how to make them, if people are intrested.
Comments about the pircuture:
The first picture is how the LEDs are placed
The second pic is the mounting in the fog light hole
The third pic with with the cover and protective covering, excuse the mess from the silicone adhesive before i cleaned it up.
The fourth pic is from the front. The fog light on the right (drivers side) is the new LEDs and the light on the left (passenger) is stock. Its difficult to tell that its brighter.
The final pic is the lights shinning into my garage. You can tell here that the LEDs are a bit brighter then stock.
