Old 12-22-2007, 09:05 PM
Gubi's Avatar
Gubi Gubi is offline
Front wheel hub nut size?
Anyone know the size of the nut on the front wheel hub? I'm changing rotors soon and want to make sure I have all the tools lined up beforehand. Also the approximate length of the appropriate cotter pins.
Thanks.
1991 Spider
1987 Milano Gold
Old 12-23-2007, 05:23 AM
SamW's Avatar
SamW SamW is offline
I don't think you need to worry about it too much, they are not really all that tight, I think you could use an adjustable wrench with no problem, I would be more helpful but I swapped them out for the Mercedes Pinch bolts years ago.
'86 GTV6 - No Name
'89 Spider Quad
'89 RC30
Old 12-23-2007, 02:36 PM
Gubi's Avatar
If I used a adjustable wrench on a nut where I should be using a socket, I'd have to kick my own butt on general principle Besides, I need the socket to use with my torque wrench to properly set the bearing preload.
I did find my big bag o' cotter pins, though, so that part is good. Just would be nice to have the socket in hand before I start taking things apart.
1991 Spider
1987 Milano Gold
Old 12-24-2007, 02:14 AM
Doma75's Avatar
Doma75 Doma75 is offline
the bolt is 24mm
Old 12-24-2007, 10:33 AM
Gubi's Avatar
Sweet, thanks. You've saved me a mid-job trip to the store.
1991 Spider
1987 Milano Gold
Old 12-24-2007, 09:26 PM
Duk Duk is offline
Originally Posted by Doma75 View Post
the bolt is 24mm
or 15/16ths for the metrically challenged
Alfa 75 Potenziata
Supercharged AW11 MR2 (soon to be twincharged)
RB20DET S13 Silvia
Old 12-24-2007, 10:22 PM
Gubi's Avatar
Use English wrenches on an Alpha? Blasphemy!
What's the torque spec for the nut in furlong-pennyweights?
1991 Spider
1987 Milano Gold
Old 12-24-2007, 11:18 PM
Duk Duk is offline
BAHAHAHAHA! (Had to laugh!!!! ). Thats AF (Across Flats) not Pommy Whitworth
What's an Alpha?
Alfa 75 Potenziata
RB20DET S13 Silvia
Old 12-25-2007, 12:41 AM
Gubi's Avatar
An Alpha is me typing after too much eggnog...
1991 Spider
1987 Milano Gold
Old 12-25-2007, 02:37 AM
Duk Duk is offline
'tis the season . Enjoy!!!!
Alfa 75 Potenziata
RB20DET S13 Silvia
Old 12-25-2007, 08:15 PM
scott.venables's Avatar
scott.venables scott.venables is offline
Send a message via MSN to scott.venables
I don't think there is a torque spec for it. I just did it up till the bearings felt right and put the split pin in.
Seasons greetings!
Old 12-25-2007, 08:48 PM
Gubi's Avatar
Actually, there's a pretty specific preload procedure for the bearings in the manual. No idea how critical it is, but I plan on following it.
1991 Spider
1987 Milano Gold
Old 12-26-2007, 12:12 PM
fast-alfa75's Avatar
fast-alfa75 fast-alfa75 is offline
You have a part number for the Mercedes application? This is a nice upgrade, as the 911's have as well. Always appreciated the precision. Thanks.
  #14 (permalink)
Old 12-26-2007, 01:09 PM
SamW's Avatar
I don't have a part number, pulled some(many) from "Pull-a-part" from some older Mercedes (I think late 70's early 80's 2XX models). I think I still have stash of them in the shed, if you want a pair, I can see if I can find my bag, you can PM about postage. You will also need an extra set of washers so you can get an allen wrench around the lip of the hub, also need to grind just a touch off the allen bolt so the dust cover fits back on.
'86 GTV6 - No Name
'89 Spider Quad
'89 RC30
  #15 (permalink)
Old 12-30-2007, 05:32 PM
BigSwede's Avatar
BigSwede BigSwede is offline
Always make the bearing loose though, not good.
I actually put the wheel back on and turn the nut until I can't feel any play in the bearing. Then install the split pin (you might wanna take the wheel back off first.).
Mats Strandberg
GTV 2000 -77 Pics <= These are picture links you know...
75 Turbo -87 *sold* Pics <=
