04-15-2004, 01:46 PM
OK-OK Intake Heat; Air Box versus Cone-Filter
Well, I didn't want to "bleed" all over Eminence's questions on intake vent-plumbing, but this subject came up again, (sorry April) so I do want to post a new thread and pose some thoughts as well a quest for some real-world testing...
This whole cone-shaped air filter charger (K&N and others), versus the standard air box (hot air vs. cold air induction) subject, has had me going for a good bit now... We can all agree that cool air is better, so this obvious point aside:
Maybe at a complete standstill, no fan blowing, right at the moment when you spike that throttle, there is a small difference in air temp going down, but once you’re rolling? Once this car is moving, there is so much air (force) flowing past that damn engine (and filter), there "can't" be any (much) residual (ADDITIONAL) heat dispersing vertically (and forward) 12, 14 inches adversely affecting the volumetric air densities by anything measurable? Please read on before knee-jerking
I am sorry, but I don't buy it and I am about to tape a thermometer of some kind, (anal or rectal?) - first to the INSIDE of a standard air box application), then to the outside of it, then to the inside of the cone-filter and again to the outside of it - (assuming that this part of my highly technical research should at least produce matching numbers.) -all to prove that the differences are negligible!
Yes, cool-air plumbing vis-à-vis an air-scoop of sorts is going to benefit the application greatly, but it will do so FOR BOTH applications!
In any case, my standard setup had this huge (18 to 24 cubic inch gap ahead of the box where it would be sucking in all manner of heat under the pro-box theory.
Naturally I will be conducting my scientific research under idle and driving conditions.
As a side-note: Ask anyone in Houston, Texas for example. 1 hour in summer traffic and that air box of yours is so hot to the touch; you can't go near it to change the filter that's inside it. Seriously, the clamps burn the cr*p out of your hands – it has to be 150 degrees in there… (Since the air outside is already 100 at that point…
Let’s find out, shall we?
Full-Race 3.7 Litre 24v Milano; Street/Track 3.0 Litre 24v Milano Verde; 2.0 TS '73 GTV; 6-speed 3.45 litre 24v Street 164 LS/Super; '06 Scion XB - Runs!
04-15-2004, 02:00 PM
Testing is the only way to know
exactly how much is lost by using a non-ducted cone.
When I worked at the VW/Audi tuner, we actually did back to back dyno (MAHA with 98kph full range fans pulling air from a box on the roof of the building) tests of high quality cone vs airbox on an A4 1.8t. Of course the Audi has a full belly pan to channel air flow, and the Milano is nowhere that sophsiticated. The loss on the Audi is between 4 and 6hp, depending on ambient air temps. Just sheilding the cone gained back between 2 and 3hp, depending on outside temps. We also played with cone inside airbox and lost around 2hp using that set-up. As for fan wash, it's not really so much an issue on the newer cars, as they have pusher fans, not the puller types inside the engine bay.
I can really feel the difference in throttle response when I install the airbox. It's the old intake velocity, tube diameter, intake length equals torque issue. Of course it tends to make the car more breathless at higher rpms. Nizam's 75 gained a lot of low end power when he installed the long 164 style intake runners.
I still use the cone because I just love the sound around town. Almost sounds like I've got a blower up front  That and the Supersprint makes it an aural treat
04-15-2004, 02:42 PM
JungleJustice,
Someone did just the test you are contemplating when comparing the stock Spica air box and the Shankle Quadraflow set up on Spider. They used a thermocouple and drove around under various conditions.
The difference in temperature of the air in the airbox was startling - it was much cooler, even at highway cruise.
Joe
04-15-2004, 03:36 PM
Joe,
The stock SPICA air box was cooler?
'69 1750 GTV
Cogito, ergo Alfa Romeo
04-15-2004, 04:17 PM
Yes, the stock Spica airbox was cooler under all circumstances than the Shankle Quadraflow with dual filter boxes and no air box.
Garrett, were you still there at the dyno day when Steve Hartung's '88 Spider GAINED 4 rwhp when he removed the cone filter and put back on the stock airbox?
04-16-2004, 12:27 AM
Did he just switch the filter for the airbox or did he actually adjust the carbs/spica?
Just slapping on another filter without adjusting would hardly be the best way IMHO.
I changed the airbox for a cone on the 75 TS I had a couple of years back, made a serious heat shield and opened up the sheet metal in front of the filter (next to the radiator behind the grille) and I felt a bit more power around 5000 Rpms.
Naturally all this is very un-scientific, the extra peak was there but for all I know the whole power curve may have been moved down and just added a spike around 5K.
Loooved the sound though, everybody else too.
Mats Strandberg
04-16-2004, 02:27 AM
75/Milano manuals for all
G'day All,
Just joined and I couldn't leave this one alone.
Last year I ran some tests on my TS and these are the results as posted to the Yahoo Alfa75 group.
________________________________________________
G'day All,
I had a play today at measuring what effect My air ram has.
The ram is 75mm (3") ducted straight from the air box out between the
right headlight and the radiator.
I connected an air pressure sensor and placed it inside the air box.
I took readings at various revs and speeds to see what happened.
I then placed the sensor on the other side of the air filter to see
what sort of restriction a standard air filter caused.
I do not have readings with the standard air inlet pipe.
Results,
Ambient air pressure 1021mb 14.80psi
Outdoor side of air filter / AFM side of air filter
1000-3000 rpm / zero kph 1017mb / 1014mb
1000 rpm / 100 kph 1020mb / 1015mb
3000-5000 rpm / 100 kph 1018mb / 1018mb
in mph/psi /
1000-3000 rpm / zero mph 14.75psi / 14.70psi
1000 rpm / 60 mph 14.79psi / 14.72psi
3000-5000 rpm / 60 mph 14.76psi / 14.76psi
I appears the air ram provides some but not much 'boost' and that the
air filter is very free flowing.
Not quite scientific, but done with reasonable care. I should also say this was an old air filter.
In another post I gave my opinion about k&n filters. I don't want to start a war (at least not on my first day) but:
_________________________________________________
First off it was me who did the cold air feed ( see
http://photos.groups.yahoo.com/group...TS+Cool+Air+Ra
m&.src=gr&.order=&.view=t&.done=http%3a//briefcase.yahoo.com/ ) and
pressure tests and yes the standard Alfa filter is very good.
The K & N is louder, thats about all.
The standard exhaust is fine, more than large enough for a 2.0l.
Lower the 75 2" and all you will be able to drive on is the local ice
rink. Measure the ground clearance under the sump and cat, you will
want 100mm min if you want to clear speed humps.
Craig
1988 75 TS
Melbourne Australia
pla·ce·bo
n. pl. pla·ce·bos or pla·ce·boes
1/ A substance containing no medication and prescribed or given to
reinforce a patient's expectation to get well.
2/ An inactive substance or preparation used as a control in an
experiment or test to determine the effectiveness of a medicinal
drug.
3/ Something of no intrinsic remedial value that is used to appease
or reassure another.
4/ (plä-chb) Roman Catholic Church. The service or office of
vespers
for the dead.
5/ I spent money on it, of course it's better.
Sorry if I have offended anyone
Craig.
P.S. for manuals, see my site.
04-16-2004, 02:46 AM
Well, nobody really says that the original paper filter is bad or are they?
It's the original installation on the TS which clearly is there for sound restriction purposes, the looong pipe with small diameter that is attached to the airbox and if you look at a used filter you can actually see that the whole filter surface isn't used, only a small part where the intake to the box is located is really dirty. You changed this when you built a RAM-pipe.
See the other thread for my thought on cone-style filters...
BTW. Have you felt the weight of that filter box??
Mats Strandberg
04-16-2004, 02:59 AM
Ok, we have basic agreement except I prefer the quiet.
Yes the standard air box is heavy, helps to balance out the battery
Craig
1988 75 TS
Melbourne Australia
04-16-2004, 04:39 AM
Craig,
Where did you get the bits to build that "RAM" section? By that I mean where did you source that white ?plastic? item to go through the bulkhead?
Photos attached for clarity.
Simon
[img]http://people.mail2me.com.au/~holywells/alfas.png[/img]
[url=http://www.alfasprint.com.ru]My Alfa Sprint Webpage[/url]
[url=http://www.simonholywell.com]SimonHolywell.com[/url]
[url=http://www.alfasprint.com.ru/downloads.php]33 Workshop Manual Download[/url]
04-16-2004, 06:58 AM
Looks like a speaker bass-reflex tube to me, commanly available and are usually the perfect shape for the job. Cheap too, and light.
Mats Strandberg
04-16-2004, 07:20 AM
Thats what I was thinking, but I was hoping Craig could confirm my thoughts.
Simon
04-16-2004, 08:43 AM
Joe,
I had already left before Steve ran his car on the dyno. I can't say I'm really surprised. For a long time now I have known the stock Spica airbox is "a marvel of efficient and quiet performance", to quote Pat Braden.
'69 1750 GTV
04-16-2004, 12:51 PM
Completely non-technical, but I had the chance to try a set of Quadraflow filters in place of the stock SPICA box for about a week last month as I was thinking about the switch, despite what Pat said in his book. WRONG!
What a difference!
It felt like she lost power in both the middle and upper RPM ranges, even though the sound was wonderful. Just did not seem to spool up as quickly either. And I lost fuel economy.
Again, all very subjective and just my opinion. I passed on the Quads., and am in the process of cleaning-up, painting, and taking care of my original SPICA canister.
What a marvel of engineering!
Get out there and DRIVE!!!
Bill
'78 Spider
