Yes I am still using a stock front sway and I'm not going to change it anytime soon
Having a bigger rear sway and standard front sway helps offset the weight of the V6 motors and makes the car turn nicer. I was speaking with Ron about this aswell and his findings are also similar.
And yes the rear roll center mod is lowering the pivot point of the watts, and the front uprights raise the roll center.
The ride with the larger torsion bars is excellent, I used to run my Koni's on full strength which made it harsh but back a knotch as per Benincas recommendations (and my konis were badly damaged from it) make it very very nice for how stiff it is, even on the ****ty roads where I live.
I used to run an in-car camera but the vibrations killed it, I don't want to try it with my new camera but I may start using the helmet cam again as it doesnt get the vibration effect
Btw the car puts down 171rwkw, or 230rwhp. And yes it sounds great
