  #16 (permalink)
Old 09-04-2007, 11:57 AM
alfaspence's Avatar
alfaspence alfaspence is offline
sorry to barge in un announced!!
nose weight is an issue, but i'll agree with JJ, bodyroll plays a big part in how precise these cars (well most anyway according to the Jag i used to have) steer and take corners! bodyroll tends to over exagirate the motion momentum!
Spence
75 3.0 24v
  #17 (permalink)
Old 09-04-2007, 01:09 PM
junglejustice's Avatar
junglejustice junglejustice is offline
Corrected: yeah - I meant at the rear...
JJ75 - I agree - D1 (his Demo car # 1 with the CF hood and trunk and the long shifter), is brlliant - headed back again next month - gotta go and get my fix!
Full-Race 3.7 Litre 24v Milano; Street/Track 3.0 Litre 24v Milano Verde; 2.0 TS '73 GTV; 6-speed 3.45 litre 24v Street 164 LS/Super; '06 Scion XB - Runs!
  #18 (permalink)
Old 09-04-2007, 02:13 PM
JJ75, Are you seriously are asking me if I have done the calculations to prove that at 32mm bar won't fit through a 31mm hole? Excuse me while I fire up the Univac to figure that out.
I don't have the exact measurements in front of me, but I am certain that the big front bar from RS racing is as large as it can be and still fit through the forward jacking point, at least on U.S. spec Milanos.
Handling is highly subjective so I tend to stay out of those discussions. However in this case I will chime in and say that I find handling with the RSR kit on a Milano to be very nuetral with driver input easily able to swing it toward oversteer or understeer.
Greg Gordon,
www.hiperformancestore.com
  #19 (permalink)
Old 09-04-2007, 03:01 PM
Grant's Avatar
Grant Grant is offline
Hey John, how much more are the adjustable shocks than his normal shocks?
1984 GTV-6 - 80K miles
  #20 (permalink)
Old 09-04-2007, 10:02 PM
JJ75 JJ75 is offline
Greg, I misunderstood what you called jacking points.Easy modifications to make the hollow-bar fit. Offcourse the swaybar mounts should be reinforced, but thats a modification required even with 28mm solid bar.
  #21 (permalink)
Old 09-05-2007, 12:18 AM
Adjustable shocks set = 1795 Euro for the 4 corners (versus 1295 Euro for the non-adjustable shocks set of 4 corners...)
  #22 (permalink)
Old 09-05-2007, 12:38 AM
Grant's Avatar
Thanks, that's just what I was looking for!
  #23 (permalink)
Old 09-05-2007, 01:57 PM
JJ75, got it, thanks.
  #24 (permalink)
Old 10-07-2007, 08:31 PM
Looks like Ron is headed States-side again in December! We'll probably make it down south to Jes' as well...
  #25 (permalink)
Old 10-08-2007, 04:18 AM
conedriver's Avatar
conedriver conedriver is offline
George Schweikle
Not to distract from the V-6 discussion, but here's an example of a lightweight swaybar on my '76 Spider. It is hollow, with splined ends and aluminum lever arms. Purchased from Orion Motor sports (Jack Beck). Current price $650.00
Originally Posted by Grant View Post
The RSR bar is quite heavy but I don't see how a hollow bar would be able to be used with out special sway bar mount brackets. I think the 30mm bar is already at the limit of the bracket's diameter, I think utilizing a much larger bar would become quite complicated, quite quickly.
George Schweikle
Scuderia Non Originale
  #26 (permalink)
Old 10-08-2007, 04:58 AM
Echo Leader's Avatar
Echo Leader Echo Leader is online now
Any east coast tour dates?
James
1984 GTV6
  #27 (permalink)
Old 10-08-2007, 08:11 AM
Grant's Avatar
Thanks for the picture! The problem I think is that a hollow bar would need larger than 30mm for the stock sway bar bracket. Nothing a little junkyard shopping and some work woudln't solve, but a hastle none the less.
  #28 (permalink)
Old 10-08-2007, 11:26 AM
No plans as of right now unless I can guarantee some sunshine... Ron came here last winter to escape, well, winter - still talks about how cold Seattle and New York were...
We'll see - I'll keep you guys up to date!
Cheers, JvR
  #29 (permalink)
Old 10-08-2007, 01:36 PM
Here is mine. New bar mounts are easy to fit. No more skills than welding reinforcements for stock mounts.
