  #76 (permalink)
Old 05-22-2008, 06:12 PM
Bill-Sims's Avatar
Bill-Sims Bill-Sims is offline
Steering quickener
Did some research tonight, and Howe Racing makes a couple of small quickeners that could be suitable for my application, especially the 1.5 to 1.0 ratio. But problem is that though the class rules allow a steering quickener, they do not allow any modification of steering column inside the car. Looks like there is not enough clearance between the firewall and the steering rack to fit a quickener and coupler.
Bill
  #77 (permalink)
Old 05-22-2008, 07:29 PM
Hit an Apex's Avatar
Hit an Apex Hit an Apex is offline
Hi Bill,
I would NOT just cut the belt off and go autocrossing.
With my 15" rims and sticky tires, without that belt turning the wheel at low speeds was a joke and I would have been dead in the water at an autocross.
  #78 (permalink)
Old 05-22-2008, 07:48 PM
Simply removing the belt makes the steering quite heavy. I wouldn't do it.
Greg
  #79 (permalink)
Old 05-23-2008, 09:25 AM
Bill-Sims's Avatar
Yep, that's what I was thinking--the inoperable pump would not let the pressure pass through, at least not very fast.
I have 245/35-18 Kumho V710 race tires on front, and they'd be really hard to turn fast at very low speeds, like we get when we have a course with a 180 degree pivot.
I'm betting the problem I've had is just a bit of the pump sucking air during cornering.
Not at all excited about pulling the rack to convert to manual. Would be easy if engine were pulled, but with headers there isn't much room from underneath....
  #80 (permalink)
Old 05-26-2008, 05:00 PM
alfettaparts alfettaparts is offline
Filling with grease
Ok is there a easy way to fill the rack with grease ie:god i do not want to take the rack out.
If i fill the bellows up with grease I wonder if enough greese will get past the ends of the rack. Im guesing not especially as the rack is desighned to seal in fluid.
What about pumping grease into the fluid ports?
Anyone?
  #81 (permalink)
Old 05-26-2008, 05:24 PM
Alex Csank's Avatar
Alex Csank Alex Csank is offline
Trogdor the Burninator
Send a message via AIM to Alex Csank
Anyone?
Please try the Lucas Power Steering Stop Leak stuff. You can buy it at any good auto parts store. It is very thick stuff and I have had it in my Milano for about a Month now without any more leaking. It's definitely worth a try.
Cheers,
Alex Csank
Chair, Alfa Century 2010 - The AROC USA ALFA Centennial Convention
Secretary, AROC Capital Chapter
Member, Scuderia Non-Originale
E-mail: alfaromeodriver@cox.net or alfacentury2010@gmail.com
Mobile: (757) 636-9513
Home
: (443) 275-1834
82 Spider Veloce (Desideria - Kathleen's)
84 GTV6 Maratona (Mona - resto project)
88 Milano Verde (Trogdor The Burninator)
"My name is Alex and I am an Alfaholic."
Alfisti are always welcome in our home!
