05-02-2007, 11:18 AM
Originally Posted by BigSwede
Potenziato: How old are those numbers? Are they from Ron himself? Looks like we will have something do discuss at the dinner table 1½ week from now because I totally agree with TS-turbo.
The numbers are from Ron. They are little over three years old. It states to use toe in as described to reduce the tire wear from the extreme camber and to increase high speed stability. I believe these are street recommendations.
Louis
1987 75 RS 24V
2004 BMW M3
2002 Porsche Boxster
05-02-2007, 11:48 AM
Confusing. I've heard from another source that you want toe-out with high amounts of camber to reduce tire wear..
1984 GTV-6 - 80K miles
05-02-2007, 12:53 PM
Toe out (excessive) would wear out the inside of the tire just like large negative camber. Isn't this similar to the 164 recommendations from Centerline to run toe in between 4-6mm?
My old lowered 164 ran about 2.5 degrees and they tend to run alot of negative camber. Of course it had great grip with that much camber!
Louis
1987 75 RS 24V
2004 BMW M3
05-02-2007, 01:01 PM
How'd you like your lowered 164? Was it an S, L? How low was it?
I saw an L that was converted to S specs one time, and it was slammed...looked bitchin'.
Also, I don't see why a lot of toe-in wouldn't wear the tires equally fast, especially with tons of camber. What am I missing?
05-02-2007, 01:21 PM
My old 164 was an S with Squadra chip, Supersprint muffler, Eibach sway bars, Sparco springs, Koni rear shocks, poly bushes, etc. I had a set of 156 16 X 6.5 wheels with various P Zeros. I had removed the airbag and put in a nice Momo. I still have the adapter.
Pretty good handling but serious wheelspin in low speed tight corners. The brakes are marginal on the 164 in my opinion. Loved the fast steering rack in the 164 S. The car in general was miles away better built than the Milano and a better turn key driver.
Oh, it had the factory Recaros too.
Louis
1987 75 RS 24V
2004 BMW M3
05-02-2007, 02:58 PM
Originally Posted by nizam
Mats - are you coming to California? Which thread was this posted in?
You're not reading it correctly. I meant as in dinner with Ron.
Prolly will go to Cali too in the not to distant future, a friend is there for a year and is telling me I need to visit. Should I go or will there be a stoning if I show my face?
Mats Strandberg
05-02-2007, 03:00 PM
Where in CA would you be visiting?
Jes
87 Milano 3.7 24v - race car
05-02-2007, 07:59 PM
Do you mean steady state cornering? Because you could have the rear end come out under power with the road tires, and not with the slicks. You don't mean that right?
Obviously it was a lot more taily under power, but also on turn in or in any trailing throttle situation. The difference grip characteristics of the road tyres changed the balance of the car dramatically. Thinking about it, it was probably due to a combination of factors including tyre compound, construction and the level of spring and roll stiffness not suiting each other with the street tyres. Similarly, the car gets more taily as the race tyres wear out, but not to the same extent.
Oo=V=oO 1974 2000 gtv oo=v=oo 1983 gtv6 2.8
05-03-2007, 12:16 AM
Jes
San Diego.
Mats Strandberg
05-03-2007, 10:40 AM
... i agree for high speed stability(ring is very high speed track)
but toe in for compansating lot of camber? very strange ... heavy camber cause toe in even if toe is set to zero ... so heavy i camber+ lot of toe will bust tires very fast !
05-03-2007, 02:43 PM
Why does heavy negative camber cause tow in? Is this why I've read someone mentioning camber thrust, and using tow out to counteract this?'
Mats,
San Diego is a beautiful place. The area near Jes is even prettier!
05-03-2007, 03:22 PM
But a bit uniform. Though, very nice along the coast. Mats, I'm 1h north of San Diego. Let me know if you visit SD and perhaps we can work something out. Zamani, Nizam, Grant, etc. are all in the Bay area. Though, if you do visit CA I'm sure you will plan to visit San Francisco.
Jes
05-03-2007, 03:36 PM
I don't know what you heard but for the record, I only go for the girls.
Mats Strandberg
05-03-2007, 07:55 PM
We got those. How much did you want to spend?
05-03-2007, 11:58 PM
Real girls, in Frisco? No snip job?
Hmm, what was the topic again?
Mats Strandberg
