04-30-2007, 04:48 PM
Anyone besides me notice that Callaways Corvette C16 uses supplemental coilovers to the composite leaf springs exactly like the RS kits uses the springs to supplement the torsion bars?
Louis
1987 75 RS 24V
2004 BMW M3
2002 Porsche Boxster
04-30-2007, 04:53 PM
Cchan, Idon't think that will be necessary. I learned alot about your setup already with your post.
Louis, I didn't know that, I thought the RS kit was one of a kind. I wonder why Callaway went that method...I thought stiffer leaf springs were easy to come by. Ride quality maybe?
And the PM is fine. After the track event on Sunday let's do a swap.
1984 GTV-6 - 80K miles
04-30-2007, 07:29 PM
One key aspect is that you can leave the coil-overs partially unload (red tender-springs not fully compressed.)
This has the torsion-bars carrying ALL of the car's weight, as well as ALL of the initial suspension compression - leaving you with a completely stock ride-feel - until you load a corner, the rattle-springs compress fully and the RSR coil-over springs are activated...
05-01-2007, 11:08 AM
Hey Jon, are the rear springs progressive? Does it feel like the front end is soft at first but the rear end is fully stiff? Or not?
05-01-2007, 06:21 PM
Grant,
You can look at the photos. The coil looks to have a linear rate, IMO.
05-01-2007, 06:50 PM
The RS springs are all linear rate front and rear. The little spring in the front is a helper spring that does nothing other than to maintain tension to keep the spring held tight.
Louis
1987 75 RS 24V
2004 BMW M3
05-01-2007, 06:58 PM
Can you adjust preload on the RS dampers?
also LOLOLOL on Colin Chapman references!
05-01-2007, 07:05 PM
Originally Posted by Grant
I'm fully aware that spending more money on tires, or going to a driver's school (thanks jj) will net me faster lap times, for less effort.
I am curious to what kind of tires you are running. I really suggest you throw on a set of the Hankook DOT-R Compounds or something similar.
You can create a new car as far as suspension work goes, but it won't do anything too special if the tires are not sticking.
05-01-2007, 07:08 PM
This is very true. If the tires don't grip, how can you adjust the suspension to compensate.
The better street tires and comp. tires make a huge difference in grip. Certainly, the balance of a car can change totally with a good or bad set of tires. I love the Michelin PS2 but they don't make a size that would fit on a Milano. I guess Eagle F1 or the better Yokohama street tires are great choices.
Louis
1987 75 RS 24V
2004 BMW M3
05-01-2007, 09:08 PM
The traditional RS suspension present on a number of US 116 transaxle cars by now has non adjustable shocks. However, Ron now also offers shocks that are adjustable for the 116 cars.
Jes
87 Milano 3.7 24v - race car
05-01-2007, 10:55 PM
Jes
Oh, I didn't realize that. So, it's one size fits all?
I.e. if you replaced the springs, you don't have to readjust the damper settings? Wouldn't you normally want spring rates that match the damper rates?
05-01-2007, 11:13 PM
Depends how fussy you are. Most people buy Konis or Bilsteins and use them with a variety of springs (that could be different by 20% or more) and don't notice any problem.
Oo=V=oO 1974 2000 gtv oo=v=oo 1983 gtv6 2.8
05-01-2007, 11:48 PM
So, I don't have my comupter with me this week but, here goes:
75evo,
I thought coil diameter changes as well as the spacing of the gap between coils had to do with linear/non-linear. I'm wrong though
Monty,
My intention is to try to dial in my suspension before I go killing expensive tires with excessive understeer/oversteer. Then I'll be able to afford used Hoosiers or something
What's so funny about the Chapman references?
@Louis - I think the way a car will handle at the limit will be roughly the same whether you have cheap or expensive tires. I know steering response won't be as good with the cheapies, but I don't think and understeering car will turn into an oversteering car with a trip to the tire store. Eagle F1's are baller!
And, I think Louis' spring rates were too much for the dampers. Felt a bit underdamped from the short ride I got. Maybe with softer springs they'll be just right? What do you think Louis?
05-02-2007, 12:56 AM
My experience in our 105 racer is when it was balanced on track tyres (sticky as the proverbial) it oversteered on road tyres. Haven't really worked out why...just accepted it. This is however, an extreme example (difference between road and track tyres is immense).
05-02-2007, 01:50 AM
Do you mean steady state cornering? Because you could have the rear end come out under power with the road tires, and not with the slicks. You don't mean that right?
