#46 (permalink)
Old 04-29-2007, 12:41 PM
Grant's Avatar
Grant Grant is offline
Jon, please know that I'm not looking for a street-fight, seriously. I'm not attacking your credibility, just the validity of using Chapman's theory on our cars. I still think that saying something a wee bit vague about what Colin Chapman said and implying that it's the case for our cars just wasn't proving anything to me. I was asking for some more clarification. I think if you'll re-read that section of my post you will see that I'm not attacking you anywhere, Jon.
I just felt that I was getting a ton of information about RS kit that I have read dozens of times before. I stated in previous posts what my gripes with the system was. But in the end, you all are right -- until I drive one of these cars, all I can do is gripe. I may end up liking the system a ton. If I do, I have a GTV-6 to put an RS or Beninca setup on. I've been carefully reading the other poster's input and weighing their arguments and some of them were convincing. I just had a few problems with some of the points in your one post.
Also, I've sated before that I'm just a college kid. The only info I have is what I've experienced in my own cars. (I know that when I lower and stiffen other cars, they grip really well. When I did the same on my Alfa the results were pretty dissapointing.) I'm just looking to see if my theory is a waste of time or not, and many have said it is. But as I said, I'm pretty far down the road and I think that this will be a good learning experience for me. I also want to be able to update this thread with that I find for future reference.
As far as driving is concerned, I do have some experience with my schools FSAE race car. I'm not 100% n00b either.
No hard feelings?
1984 GTV-6 - 80K miles
  #47 (permalink)
Old 04-29-2007, 02:19 PM
slyalfa slyalfa is offline
I might have some input that might or might not help?
and it goes along the Chapman's which seems to say some cars are better the others . well yea.. so what.
Lets take a chepo strut car very common any roll and that will tilt the tire no matter what. so stiffer car big big improvement.
now take a double A which as function we are. If the lengthes are right we can roll as much as we want and keep the tire flat. Which Alfas are knowen for great grip with soft springs. Even look at the gtv when it first came out the reviews even knocked it due to the amount of roll it had even when it out cornered all the other cars in the review. (aka othe other cars had to use stiffer springs and still did not do as well)
And I have to say my stock springs, and on a bumpy steet have let me stomp on a lot of other cars with the stiff springs as they bounce off the road. But I know if I went to a track the same cars with the stiff springs would stomp me.
And even with good flat tires with a lot of roll if I did a zigzag a car with less roll will be better off. or very quick turns. my spider is track stiff and if I do a quick zigzag it will respong instany. on the Milano every thing is slowed down. if I go in to a slow turn I think the Milano will kill the spider. but if I do a lot of quick stuff like zigzags the spider with the stiff springs give me the instant responce that the street springs do not. but if I just go into a lazy turn and see how may Gs I can pull I think they would be close and if anything I think the Milano might win.(I think I will have to try that some time)
so I gess I am getting at there is more then just grip. the spider stays the same after a break. The Verde goes from light oversteer to more oversteer if the breaks had been used as it compress the soft springs and that uncompress for some time giving extra front grip. I have to step on it then the weight will shift and the car will stick in the back. If the spings were stiff they would not be the masive grip change front to back.
And as stated above each car is different to start with. Some where I have imporved my front so I have overster but it will go away as long as I punch it so I like it that way. but I have stock springs and sway. Just a bit of poly bushes her and there. but it seem most stock are underster so my car seem to stick a bit better then most at the front. why??? it might have to do with a bit of frame stiffing at the front? when I got the car the front was in bad shape from jacking on the frame so I weled some steel there to give me good solid jack points. but I might have also inproved the front grip some as a side affect.
given on a other post where broke there. I think I might have just welded a weak spot by luck.
I put it there to have a jack point and to stop busting headers. and I have not cracked one after I added it.
It is not clear in the pic but the L goes back along the frame past the fire wall.(I bet I lost all my crumple zone....)
1987 black Milano Verde
1972 White spider 2000 Veloce
  #48 (permalink)
Old 04-29-2007, 08:52 PM
junglejustice's Avatar
junglejustice junglejustice is offline
...it's all good Grant - here - fly up to Seattle any time (closer - and I won't charge you the 600 Euros either) and come and drive my Verde...
  #49 (permalink)
Old 04-29-2007, 09:38 PM
Grant's Avatar
Ahaha, will you be providing me fine German food and driving instruction too?!
Thanks for the offer. If I'm ever in the WA area, I'll be giving you a ring regardless.
Slyalfa, I really like the idea of that brace you have down there. Never thought of putting a brace down below. Louis likes the way his car handles without his chassis brace up front, but I think the understeer he's experiencing with the brace has to do with his front end being too stiff in the first place. Who knows?
  #50 (permalink)
Old 04-29-2007, 10:13 PM
cchan cchan is offline
Hi Grant,
When my Alfa is fully sorted, which shouldn't be too long as I will be bring the Alfa for the interior tomorrow you can drive my GTV6 no problem. It may have some of the options that you are looking for in terms of your suspension questions. Just don't push it too hard and hopefully it will help you answer any of your questions. I did not drive it too much but body roll is pretty much gone
82 Alfa GTV6-3.0 24V Restored/Modified
x-78 Spyder
  #51 (permalink)
Old 04-29-2007, 10:20 PM
Grant's Avatar
Hey, if you're nervous, I'll sit in the passenger seat. Or better yet, come out to a track event!
And regardless of this debate or not, I wanna see that beast!
  #52 (permalink)
Old 04-29-2007, 10:42 PM
Hi Grant,
I am not really part of this debate since I really don't know enough to know what the real issue is. I am not nervous but just careful. Especially, after seeing the Ferrari Challange cars race at Infineon. Almost 70 % of the cars were banged up and just don't want anything crazy to happen to the Alfa out the gate. I am sure that most likely all after market parts will enhance our cars performance. Just thought I would offer this since you asked if you could drive someones car with a RS suspension in post #40 above. Remember??
x-78 Spyder
  #53 (permalink)
Old 04-29-2007, 11:33 PM
Grant's Avatar
Hey, thanks a lot for the offer. I really appreciate it. I was thinking it over, and although I'm very careful when driving other people's cars, I don't want to do anything to put your new beautiful car at risk. How about I just ride along with you sometime? I don't think we'll be able to safely see the car's limits on the streets (unless you know a place...) so I'd be happy to just see how the car rides. How low is your car?
I don't think you'll easily be able to tell if your car understeers/oversteers or w/e very safely unless you're at the track. I'll bet your car is on rails!
Any idea what your alignment is like up front? I'm alwasy curious to see what RS guys are doing for negative camber up front.
Maybe JJ could chime in here too..
  #54 (permalink)
Old 04-29-2007, 11:51 PM
AR4me's Avatar
AR4me AR4me is offline
A lot - 4 negative. Just look at some pics of Ron's ring cars. Though, on Roxanne I'm running 0.5 due to points For the street you may want to be less aggressive (to save your tires).
BTW, if you already have Ron's front and rear sway bar, you mainly need the 4 shocks and springs to get the most of the advantage. On the race cars, both Colin and I have the 4 shocks and springs + the front 30 mm sway bar from Ron, and then stockish components for the rest.
Jes
87 Milano 3.7 24v - race car
  #55 (permalink)
Old 04-30-2007, 12:36 AM
Grant's Avatar
Jes, as you know the 4 springs and shocks are the most expensive parts!
4 degrees...that's way groovey. Did the kit come with recommendations on how much to use?
  #56 (permalink)
Old 04-30-2007, 11:38 AM
Potenziato's Avatar
Potenziato Potenziato is offline
Grant, you're a real wanker!
A real man would stop asking everyone on the internet to hold his hand to help him. I mean, put up or shut up. Buy a set of spindles if you're so smart. I mean from the get go you believe the spindles should work so they must work!
Louis
1987 75 RS 24V
2004 BMW M3
2002 Porsche Boxster
  #57 (permalink)
Old 04-30-2007, 12:20 PM
nizam's Avatar
nizam nizam is offline
Originally Posted by Potenziato View Post
Grant, your a real wanker!
ROFL!!
  #58 (permalink)
Old 04-30-2007, 12:49 PM
Grant's Avatar
Uhh....Louis, did you not get my PM? I sent it 2-3 days ago. I'm trying to buy them from you...how about you man up and sell them. A real racer woulda gotten the benefit of D-spindles and RS coilovers =)
PM me if you didn't get it.
And who said I needed help on this? Besides, don't you like debate?
And if you did get my PM, I don't think you should be charging me full price for a used set of Larry spindles. Not to mention I'm giving you a pair, so you're benefiting from the transaction. Let's strike a deal so I can buy them from you.
Don't forget to tech your car Louis. See you at the track!
Ps, let's caravan up there.
  #59 (permalink)
Old 04-30-2007, 02:42 PM
Potenziato's Avatar
I decided to cancel out at the last minute since I need do the rear brakes and as I discovered the brakes were toast the rear muffler has a nice crack in it. Time to go to the Speed Merchant and get a Magnaflow with a nice big tip!
I would caravan with you guys, but I'll be in SF. I'll try to stop buy Sunday and see what's going on.
Louis
1987 75 RS 24V
2004 BMW M3
  #60 (permalink)
Old 04-30-2007, 03:14 PM
I was driving with JJ and he showed me the difference between understeers/oversteers very clearly. Of couse, I was hanging on and hoping we were not going to crash. I maybe wrong but JJ told me if we hit the wall with the front of the car we are understeering and if we hit the wall with the rear we are oversteering. The mustang was really light and seemed to be floating at the limit but JJ was a good driver and at no time in reality were we at risk of crashing. ( Only in my mind) It was fun though and we were not on the track.
I have my print out of my Modified spec sheet for the allignment and I coud fax it to you or maybe post it if I can figure out how to do this. Camber looks like it is -2.3 for the left front & right front and -.6 for the left rear and right rear.
x-78 Spyder
