01-04-2009, 11:36 PM
Feed back from this will be enormously interesting!!!
Alfa 75 Potenziata, Twincharged AW11 MR2, RB20DET S13 Silvia
01-05-2009, 09:32 AM
Jes,
Did Richard mention anything about reinforcing the dropped spindles when he made them? Rumor has it that Beninca does to theirs and I'm wondering how necessary it is. I *think* I'm having flexing issues, but I need to change out my upper and lower bushings first to be sure.
1984 GTV-6 - 80K miles
01-05-2009, 01:08 PM
Richard Jemison
Jeez....
If you want snap oversteer, my first Verde had the recipe. Narrow et 45 speedlines, 1.5 degree negative camber, 24mm front bar, Shanlkle Sport Springs, stock torsion bars, Koni red, tire pressures: F36 R32. This was a drift car before drifting ever was invented. I got a really wide drift coming around a low speed 2nd gear corner in the neighborhood. Imagine the fun in the rain.
You guys wear me out!
The "Real Racers" typically are running "Dropped Spindles", 30mm Torsion bars, 15' tires/rims, 23.5-10.5-15 cantilevers Hoosier/Goodyear (SCCA Rules)(Light weight Tire Rim package) Large front Sway bars, Small rear bars, 125/140lb rear springs.
Wt. 2000 lbs or so.
These cars Road race and handle wonderfully.
So do street cars with 27mm TBs, dropped spindles, Stock sway bars red Konis, and cut down rear springs. (gosh, too cheap to be true!)
When you create a jumble of parts you can`t expect much....
Get rid of the high rate sway bars & rear springs.
Do what you are going to do on the front of these cars first. Cut down the rear springs to get height and drive it to see what you might need in the rear. You may need very little spring rate increase in the rear. Put what you have in a spring checker before ordering anything else. Simple Koni`s are great, both for street & track days.
Do your homework! Don`t order stuff ie: springs, suspension parts, etc, as these other nitwits on the BB knows even less than the rest! Don`t be a big wheel, big tire copy all!!
Richard Jemison
RJR Racing
http://scuderiagiallo.com
01-05-2009, 01:35 PM
I think that car Louis was describing was from a decade ago...
His blue car with the RS kit was what got me interested in it in the first place...the ride was so smoooooth...
01-05-2009, 08:33 PM
Richard Jemison
Jes,
Grant?
Who built yours?
There is no place to "reinforce" them.
The backside is right up to the rotor once modified. The cut is right at the dished area for the BJ.
We covered all this with your complaint sometime ago regarding design, and it was suggested you look into chassis rather than even poorly built spindles.
But the pics below show how they are preped. They are not just cut off and a longer part welded on. As well There are correct metallurgical guidlines that must be followed.
If they are not built correct then you might have issues, Why dont you post pictures of them here.
Richard Jemison
RJR Racing
01-05-2009, 09:07 PM
Originally Posted by Alfar7
Grant?
Who built yours?
What complaints are you referring to? Larry Jr. at APE made them. I don't have readily available pictures. The spindles are 1 and 1/8th or 1/6th inch drop. I forgot exactly.
01-05-2009, 11:50 PM
Larry didn't weld them up. I believe my set were welded up at an Alfa race shop in Berkeley.
1996 155 V6, Squadra Tuning, RJR cams
01-06-2009, 06:55 AM
I thought the whole point of drop spindles was to keep the lower arm horizontal or below horizontal, am I missing something?
01-06-2009, 08:48 AM
Correct. You can lower the car (the drop spindle will actually do it for you) without changing the angle of the LCA - keeping it level at rest. I don't think you want it below level.
Grant, sorry about the late response. There are no visible reinforcements to the drop spindle. No room as Richard said, 1/4" at most to the rotor (on my car with non-stock brakes). The strength of the drop spindle seems to be in the manufacturing process. Richard knows all this stuff very well, and that is a huge benefit of drop spindles from him. Others may know as well, but personally I feel comfortable with his work.
Jes
87 Milano 3.7 24v - race car
01-07-2009, 04:29 AM
Wt. 2000 lbs or so.
So, an ambitious fast road setup could look like:
dropped spindles, 27mm torsion bars, yellow Konis f+r, poly bushes all round, 140lbs rear springs, lowered 40mm in the rear, matching front ride height.
Why no stiffer swaybars ?
regards
Stocki
01-07-2009, 07:12 AM
Richard Jemison
Question
Stockii33:
What do you drive?
You have lowered the car, increased spring rates, anything else in the rear is just going to increase oversteer.
Read the post...
Richard Jemison
RJR Racing
01-07-2009, 08:08 AM
1988 75 3.0 QV
...So do street cars with 27mm TBs, dropped spindles, Stock sway bars red Konis, and cut down rear springs. (gosh, too cheap to be true!)...
...anything else in the rear is just going to increase oversteer.
I thought about the front end. So: Why no stiffer swaybar at the front ?
Cheers
Stocki33
01-07-2009, 08:59 AM
Excerpt from page 97, 2nd paragraph of "How to make your Car Handle" (by Fred Puhn): "To make the car understeer less, reduce roll stiffness on the front and increase it on the rear."
I was kinda hoping that you would have followed-up by now with the drawings you said you were going to do stocki. Maybe Bob (aka Bobsiopener) can provide the key rear suspension measurements (since he graciously provided the front) for the model as well?
If it helps you, here are a couple of depictions of the suspension from the Shop Manual.
01-07-2009, 10:56 AM
Stocki,
2 relatively cheap ways to improve handling (in this case decrease understeer and make the front end more responsive)
1- Change to Twinspark bumpers if you have the heavy Milano bumpers. You will have to lower the car after doing this.
2-Move the battery to the boot. I'm using a Mazda MX-5 battery in the boot/trunk.
OK back to drop spindle discussions
01-07-2009, 12:02 PM
Stocki,
I had exactly that setup described, but with a front 28mm sway bar and eventually a 26mm rear sway bar. No matter what sway bars I used, I wouldn't call it fast road. The level of grip was always a bit disappointing to me. Maybe if I had moved the battery to the rear things might have been a bit better?
