07-10-2007, 04:27 AM
Originally Posted by BigSwede
We're (at least I am) talking about the modified steering arm as seen on the above modified spindles/uprights.
I'm trying to get an answer to how he came to that position of the joint, at the moment Alfar7 is either playing dumb because he doesn't want to answer or he did it by gut feeling and haven't got a clue what really happens.
Maybe he puts the steering arm in from the top
07-10-2007, 10:10 AM
I vote for option # 2...
07-10-2007, 12:14 PM
Richard Jemison
Dropped Spindles
Sorry to have taken so long to reply, but I have been away racing.
As to why & how I modify the spindles is a result of a few years experience building race chassis not just modifying Alfa`s for racing as I have done since 1969. FYI, I am totally comfortable with my knowledge of suspension design.
The need to share how I determine the steering arm position and the design of my fixture is something I don`t need to do, along with the pre-welding process, alloys used and heat treating process. Of the many spindles I`ve modified since the first 101`s & 105`s in 1969, I`ve not had a failure or complaint with it`s function.
I share quite a lot with this forum, and the Alfaracing list, and most find it useful. Some things you are just not going to have shared . Sorry......
Richard Jemison
RJR Racing
http://scuderiagiallo.com
07-10-2007, 02:35 PM
i've had very good luck using spindles from a '92 ranger (yes, i know, a travesty, but they've been entirely bulletproof). they require very minor modification to fit, but it might be well worth trying on your alfas, especially seeing how cheap they are.
07-10-2007, 02:43 PM
That's an interesting twist to the drop spindle discussion we're having here. Can you go into some more detail?
07-10-2007, 03:53 PM
Mee too!
As far as I'm concerned, if you're not comfortable with sharing the why and howcome it's pretty pointless to show pictures of the result. But maybe that's just me?
Mats Strandberg
07-10-2007, 08:39 PM
Richard Jemison
Dropped Spindles
Maybe that`s it exactly .........
It`s not that I`m not comfortable. I am just not doing it.
Richard Jemison
RJR Racing
07-11-2007, 12:58 AM
oh, no. Now I'll never find out how to do that heavy modification. :P
I have my car sorted, without adding a pound of steel to the unsprung mass, I was thinking that maybe the other guys was interested of some actual data instead of trying to copy something from pictures.
Mats Strandberg
07-11-2007, 03:29 AM
This may seem ignorant but (and maybe i should have read the whole thread) whats the idea of this mod? my car is lowered 30mm, std bushs/ shox (for now) running 15" compo mo's...
i have nothing fouling suspension-wise at the front and virtually no under steer (rear does the work)
wot gives
Spence
1972 Vauxhall Firenza 3.0 V6
07-11-2007, 04:57 AM
Richard, are you not sharing the technical specs because you sell these and don't want people simply copying vs. potentially buying from you?
And if you do sell them, do you have a set of parameters you always build to (obviously a bit different with wheel size) or do you build each set with the buyer's ride height in mind? oh....and how much $$$?
Thanks!
James
1984 GTV6
07-11-2007, 07:58 AM
Richard Jemison
Wot Givs / Dropped Spindles
[QUOTEThis may seem ignorant but (and maybe i should have read the whole thread) whats the idea of this mod? my car is lowered 30mm, std bushs/ shox (for now) running 15" compo mo's...
wot gives
][/quote]
What about bump steer?
Look at the angles on your upper & lower A arms.
With the lower arm angled up you have lost the benefit of the unequal length A arm design, and as well, lost wheel travel.
The proper position for the lower arm is parallel to the track/road surface.
By lowering the car using dropped spindles there are at least three benefits.
One, simply is no loss of wheel travel & compliancy.
Another ,key benefit, is a longer(taller) spindle carrier(upright). (remember the knuckle risers on early 101 & 105 racecars?)
This length (added to the bottom under the spindle) increases the angle of the upper "A" arms when the lower arm is still level, which results in more camber change per degree of wheel movement.
In rebound (bump or upward movement) which on track is caused simply by body roll entering and through turns, there is a significant increase in negative camber. Enough, that rather than then having "positive camber" and loss of the contact patch between the tire & pavement as with the stock design, You actually have enough negative camber gain, to not just offset the body roll`s resulting movement towards "positive camber" but have a slight increase in "negative camber" to give the tire a better footprint on the pavement.
As well, on the other side of the car, rather than the suspension leaving the inside tire at negative camber, the droop (downward movement) of the suspension results in the upper arms moving the top of the upright farther out, moving the tire into a "positive camber" position increasing that tire`s bite as well.
When a car is incorrectly dropped so that both upper AND lower arms are angled upward every movement of the suspension moves the tire in or out severly causing major bump steer. Under braking or bump, you get "toe out", exactly what you do not want. Under droop, you get "toe in" . On the track all this results in a car with unstable conditions under braking, and unresponsive turn in.
With dropped & longer spindles , with the steering arms returned to the correct position relative to the steering rack, and with some increase in the Ackernan angles (which I do when modifying the spindles & arms), you can set up the car with less overall negative camber, with "0" toe in or out, resulting in less drag, less tire wear, and still result with correct camber footprints under cornering on both sides of the front. As well, the Ackerman changes I make result in increased "toe out" when the wheel is turned off center giving better "turn in" response, when cornering.
Please contact me off thread about having these modifications made & I will be happy to respond.
By the way,I tried to make this simple enough for JJ & BS (who`s avatar gives us a clue), but it probably won`t be enough. Useless postings
guys!
Richard Jemison
RJR Racing
07-11-2007, 08:37 AM
[color="DarkSlateGray"] In rebound (bump or upward movement) which on track is caused simply by body roll entering and through turns, there is a significant increase in negative camber. Enough, that rather than then having "positive camber" and loss of the contact patch between the tire & pavement as with the stock design, You actually have enough negative camber gain, to not just offset the body roll`s resulting movement towards "positive camber" but have a slight increase in "negative camber" to give the tire a better footprint on the pavement.
If you had a proper suspension, with correct setup, you would control that body-roll to a LARGE degree and would not need the extra pound of un-sprung steel per corner!
Guys - snake oil for these cars! Go drive any one of about - oh - what? TWENTY-FIVE of these cars at the Ring or at Spa ALL lowered and ALL with this "BAD" drop-spindle situation and NONE with this modification and then come and tell us about how poorly the cars handle. There are FEW guys here (myself included) who will ever out-drive that suspension as-is with the proper spring-rates and roll-bars added! (I don't think that sitting on the bumper of a 993/996 through tight turns is so bad... )
Let me be clear (and the guru Richard said it himself), this IS an issue that comes WITH body-roll... By adding anywhere from 100-115 to 125 kilograms of spring-rate per corner (Richard, call me if you need the conversion to pounds/inch) and by going with the RSR coil-over setup, body-roll is damn-near eliminated and this is NOT an issue anymore!
And NO, larger torsion bars will NOT do this for you (I don't care HOW large they are...)
P.S. Mats, I think father-time just called you a Total Loser...
07-11-2007, 12:39 PM
JJ, are those kg/cm numbers? And do you know the motion ratio of the GTV6? I've got some numbers I'm working with and I want to be able to develop wheel rate numbers for the available RSR spring rates. Thanks!
Still JJ, doesn't that route us right back to the concept, that was being heavily discussed on alfagtv6.com/bb, that you could achieve the same roll stiffness with less wheel rate (less spring and roll bar) by having the geometry of a lowered GTV6 or Milano itself oriented so as to discourage roll? The RSR kit seems to do an excellent job of eliminating roll through increased spring rates and a massive 30mm anti-roll bar thus these issues still exist in the suspension but are supressed...right? Why not address the issues with the drop spindle and then select spring rates and anti-roll bar thicknesses?
Hopefully that makes sense, I'm just learning...
James
1984 GTV6
07-11-2007, 02:45 PM
JJ: Looks like it. Boy, he sure got me there.
"What about bump steer?
One, simply is no loss of wheel travel & compliancy."
So by lowering the car we get McPherson? We still have the unequal length arms, just different angles. Why do you think that the best position is for the lower arm to be parallell with the pavement? Do you really think that track change is a big issue? what does your RC do?
Wheel travel? You can drop the car onto the frame before wheel travel is an issue... Let's face it, we're talking heavily modified street/track/race cars here, 50-60mm bump is about all we will ever need unless playing farmers and then the angles will be quite wrong anyway.
"Another ,key benefit, is a longer(taller) spindle carrier(upright). (remember the knuckle risers on early 101 & 105 racecars?)
This length (added to the bottom under the spindle) increases the angle of the upper "A" arms when the lower arm is still level, which results in more camber change per degree of wheel movement."
101 & 105 cars? Why do you bring them into the discussion? Because it worked on that ill-concieved chassis doesn't mean it's a carry-over solution for the 116 chassis. Do we really want more camber gain? What about bump/rebound? That will throw camber all over the place, during braking for instance you will have loads of camber producing less braking force.
"In rebound (bump or upward movement) which on track is caused simply by body roll entering and through turns, there is a significant increase in negative camber. Enough, that rather than then having "positive camber" and loss of the contact patch between the tire & pavement as with the stock design, You actually have enough negative camber gain, to not just offset the body roll`s resulting movement towards "positive camber" but have a slight increase in "negative camber" to give the tire a better footprint on the pavement.
As well, on the other side of the car, rather than the suspension leaving the inside tire at negative camber, the droop (downward movement) of the suspension results in the upper arms moving the top of the upright farther out, moving the tire into a "positive camber" position increasing that tire`s bite as well."
Rebound equals bump? Now that's a new one, to me those two are just the opposite, bump compress the shock and rebound extends it.
Here is where the roll stiffnes comes into play, if you have a roll-stiff chassis you won't need all that camber gain because there is no loss to gain back and you are left with all the negative stuff like less braking force. You can actually get better "camber gain" functionality with a lot of caster, it leans the tire in the right direction both on the inside and the outside.
"When a car is incorrectly dropped so that both upper AND lower arms are angled upward every movement of the suspension moves the tire in or out severly causing major bump steer. Under braking or bump, you get "toe out", exactly what you do not want. Under droop, you get "toe in" . On the track all this results in a car with unstable conditions under braking, and unresponsive turn in."
You will have some bump steer by dropping it wildly but it wont be incredibly badm the steering arm moves as well and the angle to the LCA will more or less be the same. I have done lots of experimenting with this and there is much more issues from chosing the wrong type outer ball joint in the steering arm Yes, there are several types that doesn't work the same! How many know that or even measure?
"With dropped & longer spindles , with the steering arms returned to the correct position relative to the steering rack, and with some increase in the Ackernan angles (which I do when modifying the spindles & arms), you can set up the car with less overall negative camber, with "0" toe in or out, resulting in less drag, less tire wear, and still result with correct camber footprints under cornering on both sides of the front. As well, the Ackerman changes I make result in increased "toe out" when the wheel is turned off center giving better "turn in" response, when cornering."
Some increase in Ackerman? Looks like it's a lot of change, this will make the bump steer problem look incredibly insignificant in comparison. Unless the person you sell the stuff to knows how to adjust ackerman the car can be pretty useless IMO.
Mats Strandberg
07-11-2007, 02:49 PM
Getting It
Guys this pissing contest is getting tiresome.
Richard has agreed to share insight into what it means to get better handling and grip. The exact methodology he doesn't have to share. Damping and spring rate is not the end of the solution for good handling. Suspension Geometry is a factor. That is what the raised spindles are for!!!!!!!
There is a limit to the theoretical spindle position would be. But this is not about theory. 1.5" is the limit. I strongly suggest referring to the books by Fred Puhn, or even Herb Adams or Carroll Smith. I've got more time than money. These (may I say) tomes will send you on a path to handling nirvana. Cheers
