Old 03-19-2007, 10:23 AM
DSpieg DSpieg is offline
Leaking rear brake -- question
Howdy folks -- my GTV6 is leaking brake fluid from the left rear caliper and, thinking back to my Alfetta days, I recall that if the pad gap adjustment screw is backed out too far, fluid will leak (as, for example, when changing brake pads). I'm hoping the solution is as simple as screwing in the adjuster a bit, but thought I'd solicit your collective wisdom first.
Thanks!
Dave Spiegelthal
Centreville, VA
'87 Milano
'85 GTV6
'77 Fiat X1/9
'71 Fiat 850 Spider
Old 03-19-2007, 12:56 PM
Grant's Avatar
Grant Grant is offline
My pad adjuster screw backed out on me one time on my Verde and leaked lots of fluid. I tightened it back to where it should have been adn the leaking stopped. This is kind of scary, so I decided to rebuild both calipers while I had my transmission out in the hopes that my rear brakes won't randomly start leaking if the adjuster screws are USED.
1984 GTV-6 - 80K miles
Old 03-19-2007, 02:12 PM
Thanks, Grant! I'm not a big fan of critical hardware backing out on its own, but I do hope that's the case this time. Now that I know it has happened to someone else I'm motivated to crawl under the car and try to screw in the adjuster and see if it stops leaking, before taking more drastic measures. Perhaps I'll stake the adjuster screw or Loctite the threads....
Old 03-19-2007, 05:46 PM
Grant's Avatar
The problem is, you're supposed to adjust the pads every now and then. I haven't been, and my pedal "dead-zone" increased more and more, until there was a lot of play in the pedal beofre the brakes worked (or that's what it seemed like.)
Complicated, these rear brakes are.
Old 03-19-2007, 09:40 PM
Gubi's Avatar
Gubi Gubi is online now
Channeling Yoda are we, mmm? A Jedi fears not these things.
It's apparently pretty normal for the adjusters to leak a bit when you loosen the locking bolt to do the adjustment. I know both of mine do, so I asked about it at one point and that was the answer I got. As long as it completely stops leaking once you re-tighten everything it should be fine.
Now, if the brakes are adjusted, the nut is tight, and it's still leaking, it might be rebuild time. Don't mess with the pad clearance to try to fix a leaking adjustment screw: get it too loose and your brakes will work like crap, get it too tight and it can drag and overheat (I've heard of fires happening this way).
I find I need to adjust the rears about once a year with typical driving to keep the clearance correct. If everything is adjusted properly (brake clearance and parking brake cable) the parking brake should set with about 4-6 clicks. Once it gets up to 7 or so I can tell it's time to adjust.
1991 Spider
1987 Milano Gold
Old 03-20-2007, 12:11 AM
Grant's Avatar
Great force, Tom has.
Old 03-20-2007, 06:12 AM
Good advice from all of you, get I.
I'll try the simple adjustment trick first, but as the brakes in general and handbrake adjustment felt fine just prior to the beginning of leakage last week, I suspect I won't get off so easy and will have to rebuild the caliper in the end.
See, we shall!
Old 08-20-2007, 10:21 AM
rjv125 rjv125 is offline
Hey guys,
I was searching through some old posts and came across this one that kinda pertains to the problem I am having with my driver's side rear brake caliper. I went to adjust the inner pad, the easier one, and when I went to turn the adjustment screw, the pad did not move inward or outward. I had someone press the brake pedal and the pad does move then, but not with the adjustment screw. Also, the inner pad does not move with the emergency brake pulled. Are these two things related? Is something stuck that can be freed up? Nothing is leaking, and the calipers are well bled. Any ideas? Thanks.
Old 12-17-2007, 05:58 AM
romroc romroc is offline
rear brakes
What is the rear pad clearance measurement? So, now it appears that the rear brakes are not self adjusting? [I'm referring of course to GTV-6/Milano rear brakes.
'58 Sprint
'82 Spider Veloce
'84 GTV-6
'89 Milano Gold
'93 164L auto
'95 Corvette C4 targa auto
'00 BMW 323 Sportwagon auto [wife's car]
The Rock
Old 12-20-2007, 07:26 AM
NMMilano's Avatar
NMMilano NMMilano is offline
I think its 0.4mm but its in the manual. The brakes are not self adjusting, thats what the adjusters are for. The inner pad adjuster is gear driven and it takes alot of turns to see piston movement
87 Milano Platinum
70 Fulvia 1.3 Rally S
Old 12-20-2007, 08:00 AM
Graham D's Avatar
Graham D Graham D is offline
#10:
.003 inch, .0762mm
Old 12-20-2007, 08:29 AM
Milano rear brake adj.
I'm now told by Tom at IAP that the rear brake clearance is 4-6 thousands. That's in inch scale.
'58 Sprint
'82 Spider Veloce
'84 GTV-6
'89 Milano Gold
'93 164L auto
The Rock
Old 12-20-2007, 12:05 PM
NMMilano's Avatar
Yep I was wrong, 4-6 thousands is correct. Pat Bradens book says .004 inches, .102mm. Thats what Im using.
87 Milano Platinum
  #14 (permalink)
Old 12-20-2007, 12:20 PM
Craig's Avatar
Craig Craig is offline
75/Milano manuals for all
Twice (sorry), the rear brakes are self adjusting, however from what others have said I believe that the adjustment is too coarse and that any self respecting Alfa owner would manually adjust the brakes long before they are worn enough for the self adjuster to work.
Craig,
1988 75 TS, 1989 164
  #15 (permalink)
Old 12-20-2007, 05:39 PM
NMMilano's Avatar
Ok I open to learning something. But please tell me how the self adjust worlks. I've just rebuilt both calipers and dont see how the "self adjustment" would work mechanically.
Both piston are fixed to the adjusters, please explain.
87 Milano Platinum
