#16 (permalink)
Old 12-20-2007, 09:25 PM
Craig's Avatar
Craig Craig is offline
75/Milano manuals for all
I can't provide details because I haven't pulled the mechanism apart myself. As I said, the information comes from others. One specifically stated that the self adjustment was too coarse which explained a lot.
Various photos from the web back up the statement that the rear calipers are self adjusting.
Did you manage to disassemble your calipers to the extent shown in pic1?
Pic2 clearly shows that the mechanism referred to in pic1 as the 'automatic adjuster' is spring loaded and more complex that would be required for a simple manual adjustment.
Craig,
1988 75 TS, 1989 164
  #17 (permalink)
Old 12-24-2007, 08:48 AM
NMMilano's Avatar
NMMilano NMMilano is offline
Yes I fully disassembled them. On further thought I never have had to adjust the brakes on my Milano except when changing pads so I'm sure you are correct.
One more question though, why do we have to set the tolerance so close? why not just set them loose and let the self adjusters do the work?
87 Milano Platinum
70 Fulvia 1.3 Rally S
  #18 (permalink)
Old 12-24-2007, 10:41 AM
sh0rtlife's Avatar
sh0rtlife sh0rtlife is offline
the ones on my gtv6 looked like that too and seem to self adjust just fine..and YES i use the E-brake when i park the car
[SIGPIC][/SIGPIC]
  #19 (permalink)
Old 12-24-2007, 12:24 PM
Craig's Avatar
Not sure, maybe just to get you around the first corner, maybe because the adjusters aren't to be trusted?
I found the reference I was looking for, this was posted on the Yahoo Alfa 75 group by Alexei (alpa on the bb):
On my page
Etriers AR Alfa Romeo 75
you'll find some pictures of the caliper internal.
I've made some tests with this caliper. My conclusion is that guys
who designed the calipers have never met those who have installed them
on the car. And those who installed them have never tested the car
more than 100km.
The self-adjuster works on the bench. I mean if I push the piston
and then pull it then the adjuster rotates and thus works.
But, in the real world we live the piston's travel required for the
adjustment is so long that anyone planing to live longer than one day
will adjust the calipers before they reach this travel.
Craig,
  #20 (permalink)
Old 12-26-2007, 01:28 PM
fast-alfa75's Avatar
fast-alfa75 fast-alfa75 is offline
Don't bother trying to rebuild these things yourself, as it seems the rebuild kits don't ususally come with all the o-rings required. An excellent resource for rebuild is Mobile Services aka Gold Line Brakes, here in Seattle. He rebuilds these things all the time for us, and does the building of the spaced calipers (ala SZ) for our big brake kits as well. Excellent service, quick turn time as well.
As for adjusting, I have chased them with the feeler gauge, and also done without. If you adjust one at a time, tighten until the wheel does not rotate, then back off for a light drag, you will find your tolerance to be within Alfa's spec.
These things are easy to remove in pairs as well. Unbolt both calipers, undo the hose, unbolt the brass union the hose mates into, and remove the pair WITH the hardlines as an assembly. This eases the pain of messing with the hardlines in car, you can reassemble on bench, then in car the hardlines are already threaded into the calipers!
  #21 (permalink)
Old 01-02-2008, 08:56 AM
NMMilano's Avatar
I'm sure there are excellent rebuilders out there, however I did mine in an afternoon and they are working fine. I did have to source the O rings however.
I agree with your adjustment method, just tighten and back off a little. I did not think they were all that difficult to remove, I dropped the rear transaxle mount to give more room. There is alot of "while you're there" work that can be done i.e. halfshaft boots, new disks and braided brake lines.
87 Milano Platinum
