Ok, here is what ended up happening. (First of all this is Sergio's son speaking, being that this is my car i thought i should have some input
). The reason we couldn't get the console containing the stereo out was because behind it there is actually a bar connected to the car and a hook on the panel that holds the panel onto the bar. If you give the panel a good shove backward it should jar free and then you can remove the console and disconnect all of the wires. As for the stereo itself the anti theft device was what was keeping it in, which being the crafty people that we are, didn't do much to stop us from getting the stereo system out. All you have to worry about are the four small screws, which can been seen from the back side, that hold the plate in. Other than that it's easy!
