Old 01-17-2004, 01:34 AM
dpo345 dpo345 is offline
Car dies in 40 degrees
Hi,
Sorry I have been posting so frequently, however my car seems to be dying on me, and I don't know what to do.
For the past two weeks I have driven around town in about 40 degree weather, a little chilly but that's it (no rain or snow.) After I park the car after driving it around, and in about 1 hour later I go and start the car up. The car starts and then dies. The oil psi gauge goes up, and then goes down to zero and the car dies. It takes only 3-5 seconds to kill. So I rev the engine and try to keep it reving while I put it into first gear and drive away. I thought at first that there was not enough oil, but now know that it is not the case. The car acts fine during the day, it's only at night.
Any thoughts?
Old 01-17-2004, 06:49 AM
Farace's Avatar
Farace Farace is offline
Re: Car dies in 40 degrees
How does it act during the day if your headlights are on? How would it act at night with the headlights off? Being a fairly new Alfa owner with absolutely no Milano experience, I'm hesitant to post, but if the problem only happens at night, my first guess is that there might be a problem in either the alternator or voltage regulator that's not bad enough yet to keep the engine from running, until the headlights are turned on, which might drop the power available to the ignition below what it needs.
Bob Farace
Old 01-17-2004, 07:53 AM
Hit an Apex's Avatar
Hit an Apex Hit an Apex is offline
we had a similiar problem with the GTV6. Would start fine, then drive it somewhere. Turn it off (temp. warm). Come back out to start it, it would fire, and shut itself off. Fire and shut itself off. etc.. We'd have to wait a long time before it would start again. Check the Plenum to make sure it is tightly one and also check all your hoses. We figured the problem to be an air leak
Old 01-17-2004, 10:50 AM
All check to make sure the hoses are all tightly secured, it has just been happening the past two weeks, but never before.
Thanks again. I will write again if it looks like everything is normal, and can't figure it out.
Old 01-17-2004, 08:03 PM
Sniady's Avatar
Sniady Sniady is offline
Send a message via AIM to Sniady
hmmm... i'm not familar with milanos, but i'll tell you what I know about the late 80's bmw's. (manufactures in those years use similar injection systems)
They have a thermo switch/sensor. It's next to the thermostat. It read's temp readings, and if it's below a certain degree's, it a activates a cold start injector. Which creates a richer mixture for those cold start ups.
If it has those, then you need to check voltage going to the thermo switch/sensor. If you have voltage, pull out the cold start injector and crank over the engine and check if its sparying fuel. If not, then you would need a new cold start.
Hope this helps.
Sniady
'how the devil do they do that with a live rear axle?'
