Old 02-03-2007, 12:30 PM
juncura1 juncura1 is offline
Front Bumper Removal
I have a new Verde and I need to pull the front bumper to attend to some body damage, but I have no idea of where to start. I tried looking on the BB for help, but I came up short. Any help or advice will be greatly appreciated.
Old 02-03-2007, 04:41 PM
test
testing test
Old 02-03-2007, 05:22 PM
JoeCab's Avatar
JoeCab JoeCab is offline
Removing the bumper is not especially difficult but can be a PIA if the fasteners are rusty and stuck.
In general you need to:
1) Remove "accordion" pieces
2) Remove lower valence and disconnect fog light wiring
3) Disconnect headlight squirter hoses
4) Disconnect main bumper piece from shocks
Joe
Old 02-03-2007, 07:11 PM
AlfaVerde88's Avatar
AlfaVerde88 AlfaVerde88 is offline
Bumoer Removal
That sounds easy enough. I was thinking the bolts were under those accordian sections. Is there a good way to do this? My accordian sections seem pretty frail.
Old 02-03-2007, 07:29 PM
aralfa8589 aralfa8589 is offline
I murdered mine when I did this. Take a long look at those sections before you attack. Good Luck!
Jeff Lang
Jeff Lang
'85 GTV6 3L, '89 Milano Gold
'91 164S, '91 164L
'89 Spider
'74 GTV project
Old 02-03-2007, 08:29 PM
JoeCab's Avatar
Soak the little attachment clips with penetrating oil for 1-2 days prior to removing the accordion pieces, then they will come off fairly easily. You also only need to remove the front OR rear of the accordion. It can stay attached to either the bumper or the valence, it doesn't matter.
Joe
Old 02-03-2007, 10:16 PM
Bumper Removal
Hey Joe, where in Colorado are you? I am in Golden. Anyway, when I pull back on the accordian pieces I cannot see any clips. However, I am not pulling back on them too far because it is cold on these bumpers are like new so I do not want to ruin anything. I have a door panel clip removal tool that is flat so I can get in there, but i am not sure of what the clips look like or how they attach. Any input on this? I appreciate all of the help.
Old 02-03-2007, 11:00 PM
JoeCab's Avatar
I'm in Westminster but I work at Centerline Alfa in Boulder.
The accordion pieces have 6 tabs (3 front, 3 rear) on the backside that push into metal clips in the valence and bumper. So, the easist way to remove is to feel the backside for these tabs and push them straight outwards. The metal clips are *very* fragile and will often crumble.
If you don't have a heated work space, I'd wait until the weather warms up or you will probably rip one of the accordion pieces.
Joe
Old 02-03-2007, 11:16 PM
Bumper Removal
sounds good. just to make sure, when you say outwards you mean outwards from the bumper so i will be using a prying motion, or do you mean outwards as in sliding the clip from the front of the car to the rear? i just want to double, triple check so can get as much information as i can. do you guys still have any Milano parts cars up there? the reason i need to take the bumper off is because the previous owner hit something on the passenger side and pushed the support back and up. i want to get that support back to where it should be and hopefull line up the fron end a bit, but i have no idea as to the extent of the damage.
Old 02-04-2007, 12:13 AM
JoeCab's Avatar
Outwards in this case means directly to the side of the car.
Again, if you pry you will probably tear something. You need to reach behind and find the tabs on the accordion pieces and push them outwards.
Joe
Old 02-04-2007, 12:16 AM
JoeCab's Avatar
Yes, we have one Black Verde that was hit in the back. Maybe next week some of the snow will melt as I haven't actually seen it since December
Joe
Old 02-04-2007, 04:04 AM
1969read 1969read is offline
Are you selling any seats from your parts car Jason
Old 02-04-2007, 08:42 AM
Yeah, I was up there last week and thought I would stop by, but the shop was closed. I did see a nice mound by the fence and thought i saw a Milano front end. I think I am going to try to get a come-along and hook it to the support from under the car and try to pull it forward so I do not have to take the bumper off. I would rather not destroy anything if I do not have to.
  #14 (permalink)
Old 02-04-2007, 02:12 PM
Gilles Gilles is offline
As Joe mentioned, the clips holding the accordeon are very fragile and will probably break when you remove them, don't worry because you can buy replacement clips at the auto parts store, they look slightly different (plastic pyramidal shape) but they will hold well the accordeon plastic tabs well in place.... as long as you don't break these plastic tabs
Gilles
  #15 (permalink)
Old 02-04-2007, 06:20 PM
I got my come-along so I am going to try and pull it back with this before I tear into the bumper. It is only about a 1/2" in and is barely noticeable. The problem with me is that I cannot stand thing with my cars out of order and when look out my window all I see is the bumper sinking in towrds the car on the passenger side. It drives me crazy. Anyway, when I dive into the body work on this car I will post some pics.
