Thanks for your reply, but how would I access the light bulbs? And when you say "brighter," is it now a bright yellow, or white? Do you have any pictures?
Originally posted by dpo345 how would I access the light bulbs?
Pull the ash-tray,
beyond are two srews for ARC-display,
remove srews and ARC,
beyond two srews (deep inside)
Remove the two plastic covers (left and right from instruments), which hold hazard-switch, fog-lamp-switch...etc.
removing from bottom-side with srewdriver...the covers are clips.
This step is not important, but it makes the next easyier:
remove the thin plastics (two srews), which hold (by clipsing) the covers.
Deep in the dash (when you looking through the hole where was placed the fog-switch etc.) one or two srews.
Now you can take the panel!
Backwards are the bulbs.
