Old 01-08-2007, 03:53 PM
eabergman eabergman is offline
Wonky gauges
New member of the list, sorry if this is a subject that's been beaten to death previously. I just bought an '87 Milano 2.5 Gold that is a runner but in need of a lot of TLC. My first Alfa. The PO mentioned gauge problems, and he replaced the entire gauge cluster. The original is in a box in the trunk. I'm still dubious about the gauges though. Just about every one of them gives some sign of errant behavior. I'll check the ground(s) but I doubt that will be a cure-all. I wondered what I can expect from them. Is there any hope for the stock gauges, or should I install aftermarket gauges for anything I really car about? Are there any aftermarket gauge setups that work especially well on a Milano?
Thanks for the pointer to Andy's Automotive, Joe. I live in Golden, and was going to ask about recommended Alfa mechanics in the Denver area.
Eric
Old 01-08-2007, 07:40 PM
Ronnie Ronnie is offline
I too am a new Milano-with-issues owner and from what I've read, the ground could well be the only problem with the guages. Maybe someone can comment who has experience with this..
Old 01-08-2007, 07:46 PM
Hit an Apex's Avatar
Hit an Apex Hit an Apex is online now
What kind of problems are you experiencing?
Once my oil pressure sender failed my water temp gauge become very very inaccurate. Once the oil pressure sender was changed it became normal again.
Old 01-09-2007, 09:15 AM
The tach does not seem to go over 3000 RPM, the speedometer waggles sometimes over about a 10 mph range, the oil pressure also waggles sometimes (over a range of about 10 psi), water temperature reads about 135 F when completely warmed up, even though there is a 165 degree thermostat installed. My biggest concern is the oil pressure gauge, or more precisely, the oil pressure. It reads 55+ psi (4 bar) cold and during warmup, but when fully warmed up it reads about 30 psi (2 bar) at 2500 RPM, drops to zero at idle. Oil is a good quality synthetic, but I forget what the seller said he used. I noticed a thread in the engine building section about sticking oil pressure relief valves on 4-cylinder Alfas. Not sure if that is also a problem with V-6 engines.
Old 01-09-2007, 09:38 AM
AR4me's Avatar
AR4me AR4me is offline
That sounds about normal I would say.
Jes
87 Milano 3.7 24v - race car
Old 01-09-2007, 09:51 AM
Jes
I was hoping someone would say that. The engine gives every impression of being tight and strong. After reading that comment about flaky oil pressure relief valves on the 4-cyl Alfas, though, I was a bit concerned.
Eric
Old 01-09-2007, 12:38 PM
DonBeeson's Avatar
DonBeeson DonBeeson is offline
The gauges arent the strong point of these cars.
In the speedometer the Jaeger sending unit below the rear drivers side seat seems to fail fairly consistently.
The tachometer sounds like a ground problem, my milano 2.5 had that problem too. Luckily it takes all of 20 minutes to access the cluster, if you do a search on this forum you will find two or three helpful threads on this topic.
The oil pressure sender at the rear of the engine is prone to failing quite often too. My gauge sometimes reads only from midway (4 bar?) to full, and then at other points it works perfectly normal. That made for a fearful 8 hour drive home when I first picked up my Verde.
Hopefully this helps, Im not sure if your speedometer problem would be in the Jaeger unit, but its well known it fails.
Welcome to the long road of Alfa ownership, I'm sure you'll love and hate it as much as we all have.
You should go around and clean all of the visible grounds on the car, it'll breath new life into your milano.
Old 01-09-2007, 01:04 PM
MitchW MitchW is offline
My Verde does all of the above as well. With the bumpy streets we've had lately I find that the guages sometimes work better. This would certainly indicate a loose connection or ground. I've removed the instruments and cleaned the contacts a couple times already, cleaned the connections on the fuse box and had some initial success but it always reverts. Next time I'm running a separate ground wire.
By the way you can see my Verde in the parking lot at 23rd and East. It'll be nice to see another Milano in Golden or for that matter in Colorado.
Mitch
Old 01-09-2007, 01:21 PM
slyalfa slyalfa is offline
I thought I had the sticking relief valves. and I had the hot knock that seemd to be normal.(reading the bb)
but when I opened it it up at around 230,000 miles the top was perfect (ring seal anyways) but the bearings were not. after new bearings my PSI ran very high even with thin oil 10-30W. and no more knock at idle. right now I have no clue other then the light as the part in the cluster went out and I have not opened to see what went wrong.
I got a cheap mechanical-oil gage with close to the same scale 0-100 PSI with a 45° sweep. so I am going to see if I can replace the works with this one and have a working good gage once and for all.
The OEM sender do not seem to last very long before they fall apart inside or leak.
and they are not very cheap. The whole mechanical-gage was somthing like $15
Also if the charge circuit is wack that will affect all the gages as Alfa seemed to not use a local voltage regulator for the gages so if the mane voltages changes so does all the readings.
1987 black Milano Verde
1972 White spider 2000 Veloce
Old 01-09-2007, 02:52 PM
Small world, Mitch. I bought my Milano from a guy about a block from there last week. Give me a call at 303-278-7445 if you want to get together for a chat.
Eric
Old 01-11-2007, 09:00 PM
juncura1 juncura1 is offline
really small worlds because here i am! hey mitch, is your milano grey? i saw a grey one running through the roundabout by taco bell.
Old 01-12-2007, 12:23 AM
That was probably me. Mine is a multicolored blue-gray rat car, and I have been up and down South Golden Road a few times in recent days.
If this keeps up we might be able to start a Golden chapter of the Alfa Club.
Eric
Old 01-12-2007, 06:49 AM
hey eric, this is benny. i saw another grey Milano running around around golden a while ago. i have also seen one in denver, one on 6th ave., and one cruising around conifer. There are a good number of Alfa's in colorado. check out the AROC and look for the denver chapter.
  #14 (permalink)
Old 01-12-2007, 08:57 AM
Mine is a grey Verde so it probably was me. I go through that round about at least twice a day. I know of a red Verde and a GTV6 in Denver and have occasionally seen a blue(?) Alfetta sedan around Golden. Other than Spiders (I've got a green Jr.) seeing another Alfa here in Colorado is a rare event and even the Spiders sightings are getting fewer.
Mitch
