Old 01-08-2007, 03:12 PM
dbgrubbs dbgrubbs is offline
ARC removal
Just a thought, is it possible to bypass the ARC panel? I was thinking about adding 3 gauges to the hole it would leave behind. From my understanding though, you can't just unplug it. Anybody done it without rewiring half the car?
Old 01-08-2007, 04:09 PM
Craig's Avatar
Craig Craig is online now
75/Milano manuals for all
Yes, you CAN just unplug the display, it does nothing else. You cannot just unplug the A.R.C. control unit above the panel above the glovebox without re-wiring the brake lights, tail lights and a few others.
Craig,
1988 75 TS, 1989 164
Old 01-08-2007, 05:04 PM
andrewg's Avatar
andrewg andrewg is offline
Great info Craig about the ARC control module. I too have a customer who wants to rewmove the ARC display to install more gauges.
ANDREWG
[url]www.garciaalfaracing.com[/url]
73 GTV - new restoration project
82 GTV6 ITS #86
85 Spider Graduate
88 Milano Verde - needs a motor, hum...
91 164S Recaro
Old 01-08-2007, 07:35 PM
Ronnie Ronnie is offline
Seems like the ARC panel would be a great location for a GPS display. Anyone done this?
Old 01-08-2007, 07:47 PM
Hit an Apex's Avatar
Hit an Apex Hit an Apex is offline
I want to. I believe someone in Australia took it out and put a LCD screen there, so someone has done it.
Old 01-09-2007, 06:09 PM
Rookie ROX's Avatar
Rookie ROX Rookie ROX is offline
There is a Milano on http://www.cardomain.com who has removed the ARC and custom made a pod so they could fit in a small screen for a dvd player. I can't remember which one it is though.
On a similar topic, has anyone fiddled with the ARC itself so it indicate a fault for something other than it's specified function? Say for example, using the ARC to indicate a flow problem/clog if there was a water/meth injection system installed? Just an idea I've been playing around with so I don't have masses of LEDs throughout the car.
ROCK ON
R~R
Old 01-09-2007, 06:49 PM
slyalfa slyalfa is offline
I took out my controler to see if the caps might be bad like all the BMWs but they all seemd to be good. but lighting leds would be easy and there is a lot of room where the controler is. (above the glovebox)
there is a lot more inputs to the box then there is LEDs I noticed. But I think the flackyness must be the power/ground to the crontroler. but I have not taking the time to run a fresh ground to see if that will fix it. but I think it is a ground problem. I have had ground problems all over. Alfa must have been runing short on black wire when they made mine as the black is streched drum tight in all the wire harnesses.
1987 black Milano Verde
1972 White spider 2000 Veloce
Old 01-09-2007, 11:28 PM
10-66kruk's Avatar
10-66kruk 10-66kruk is offline
Send a message via AIM to 10-66kruk
i have done it
i replaced the ARC and put in a monitor to play dvds on
I loved it
Old 01-09-2007, 11:46 PM
Mezevenf's Avatar
Mezevenf Mezevenf is offline
Send a message via ICQ to Mezevenf Send a message via AIM to Mezevenf Send a message via MSN to Mezevenf Send a message via Yahoo to Mezevenf Send a message via Skype™ to Mezevenf
Why didnt you use a widescreen monitor that took up the whole space instead of just half? something stopping you?
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
Old 01-10-2007, 11:40 PM
10-66kruk's Avatar
No nothin was stoppin me actually I dont really know why I just got that size. There was a reason when it went in but I can't remember. When it goes in my 3.0 there is gonna be a custom dash to go with it. Ohhhhhhhhhhhhhhh now I rememer why I went with that size. Before I crashed the car that was in I was going to put l.e.d warning indicators in that blank spot, e.x. doors open was gonna put a little clock and was going to relocate switches like the windows. That why there is a blank spot.
Old 01-11-2007, 12:01 AM
Grant's Avatar
Grant Grant is offline
That's SIIIICK man. Put some more pics up of your project somewhere.
1984 GTV-6 - 80K miles
Old 01-11-2007, 12:17 AM
10-66kruk's Avatar
i did but i tried finding it and it seems like it was deleted. I haven't done that much latley really i will have more to post soon though.
Old 01-11-2007, 06:49 AM
kredden's Avatar
kredden kredden is offline
I have to ask...you didn't crash it because you were watching Gone in 60 Seconds while driving did you? :-)
Kevin
86 Spider Veloce
87 Verde
Milano registry custodian(www.alfamilano.com)
  #14 (permalink)
Old 01-11-2007, 10:12 AM
My dad has a three gauge pod in his dash, you can see a picture of it here: http://www.hiperformancestore.com/SuperVerde.htm
  #15 (permalink)
Old 01-11-2007, 05:16 PM
10-66kruk's Avatar
Kevin
Hahahaa i wish that would have made my stupid mistake sound way better when i have to tell the story to people.
