Old 01-08-2007, 01:33 PM
fraz's Avatar
fraz fraz is offline
Recaro creep
Hey all,
I have the stock Recaros in my Verde and the driver's side seat back creeps back (aka reclined). This happens all the time while I'm driving and even if there is constant pressure on the seat back. I always have to reach down and crank the knob like 2-3 times to be in the correct position again. It's gettng old and I want to fix it without replacing my seat(s). I should have done this when I had them upholstered but forgot to mention it at the time. Anybody know of a quick fix for this?
Old 01-08-2007, 02:00 PM
DonBeeson's Avatar
DonBeeson DonBeeson is offline
I thought I was just going clinically insane but I see its happening to you to!
Mine seems to do it about once a week. I'll finally realize that i'm sitting far lower than I normally do and give it a few cranks.
No idea how to actually fix it though...just sharing that you're not alone.
Old 01-08-2007, 04:15 PM
fraz's Avatar
Aha! Except mine is multiple cranks a day like three 1/2 turns per drive. Over a 400mile trip I end up doing 3 turns about 3 times I am sure there is a simple workaround. I'm hoping somebody here has run into this.
Old 01-08-2007, 04:38 PM
75evo 75evo is offline
Me too. At first I thought I was loosing it.
Potenziato said to check the philips screw on the reclining knob (each side). Mine is tight, but I'm pretty sure it still reclines a little.
Old 01-08-2007, 04:49 PM
AR4me's Avatar
AR4me AR4me is offline
He-he... I used to watch the passenger seat gradually recline itself without weight against it. My driver's seat didn't do it, so I figured it was simply caused by vibration of the seat without weight on it - guess I was wrong. Anyway, the Recaros have since been replaced with some nice Sparco leather seats
Jes
87 Milano 3.7 24v - race car
Old 01-08-2007, 05:02 PM
andrewg's Avatar
andrewg andrewg is offline
The Verde Recaro seats have been doing this since new. I am not sure of any fixes, but it would make driving my Verde easier. Mine only needs to be adjusted once a day. It did not help to swap passenger side to the drivers side either.
ANDREWG
[url]www.garciaalfaracing.com[/url]
73 GTV - new restoration project
82 GTV6 ITS #86
85 Spider Graduate
88 Milano Verde - needs a motor, hum...
91 164S Recaro
Old 01-09-2007, 04:41 AM
SamW's Avatar
SamW SamW is offline
Mine does the same too, but mostly the passenger's side, driver side only when I let it sit in the driveway idling with out me in it, I don't think it is the screw, but I thought about filling the adjusting mech with some thick axle grease just so the vibration would have less effect, I doubt this would help if yours does it while you are sitting in it.
[COLOR=DarkRed]'86 GTV6 - No Name[/COLOR]
[COLOR=DimGray]'88 Verde w/no sunroof - Bella[/COLOR]
[COLOR=DarkRed]'89 Spider Quad[/COLOR]
[COLOR=Black]'89 RC30[/COLOR]
Old 01-09-2007, 09:46 AM
DonBeeson's Avatar
Does anyone have a diagram of the mechanism that is actually failing?
Old 01-09-2007, 03:47 PM
Potenziato's Avatar
Potenziato Potenziato is offline
I have had four cars with the Verde Recaros and only Blatta had the creep. As 75 evo said, I tightened the screws inside the recline mechanism and it went away. I had the same seats in a Corrado and never had the creep.
It is a known and documented problem with Lancer Evo's.
http://www.lancerregister.com/faq/F19/f19.html
Louis
1987 75 RS 24V
2004 BMW M3
2002 Porsche Boxster
Old 01-10-2007, 09:24 AM
Graham D's Avatar
Graham D Graham D is offline
The back side of the adjustment knob has a socket that retains a friction disk. The disk over time deteriorates and no amount of screw-tightening will truly 'fix' the problem. Contact your closest Recaro distributor to obtain OE replacements or fabricate something on your own. Be a 'guy' and let us know of your seccess.
Old 01-12-2007, 04:43 PM
fraz's Avatar
Well even if I don't figure a technical solution out of this, the therapy group helps I'll pull the knobs and see if I can find any remnant of friction disc. If I do, I can work with my machinist buddy and find a suitable material in their shop. Just have to see the mechanism first and I'll understand.
Old 01-28-2007, 07:55 PM
kuni123456 kuni123456 is offline
I took my Recaro seat out of the car and removed both seat adjustors. Each adjustor had a red sponge rubber washer that fell apart. I cut a 3/16 inch thick section out of a 5/8 inch heater hose and put it in place of the red sponge rubber washer. I carefully tightened each adjustor and the adjustors worked like new. You have to be careful to cut the heater hose in order to get parallel sides.
Old 01-31-2007, 09:56 AM
AlfaBeta AlfaBeta is offline
Hi guys,
Mine do the same thing, I need to crank about 1/2 turn once every couple days. Now if only the whole seat would creep back to give me more legroom! Actually that brings up a good point, has anyone ever modified a seat (or floor) for more driver legroom?
AlfaBeta
  #14 (permalink)
Old 01-31-2007, 03:17 PM
Rookie ROX's Avatar
Rookie ROX Rookie ROX is offline
We recently discovered our parts car seats had been modified so it could move back further. From memory it was simply two pieces of steel that were tacked on to extend the rails. Nothing special, nothing pretty, but it seemed to work.
I've always been interested in getting the seats lower like in the later models though..
ROCK ON
R~R
