Hello,
As lately in this part of Europe we got constantly rainy weather I finally decided to do something with my brakes. Since I remember the worked unevenly distributing force firstly to left front wheel and then to right one. I could live with it on dry tarmac but not on wet surface. I've always suspected that the proportioning valve was to blame, as all the lines were changed some time ago. Yesterday I decided to get rid of the valve. Well it one of the decisions which you regret just after you make it
I have EBC Red Stuff kevlar pads in front and regular pads in the rear. Front ones have significantly higher friction coefficient although only when warmed up. I expected that the difference of friction (front vs rear) would compensate job done by the valve. And it probably would but the problem is that presently I can't warm up my fronts without locking rear wheels. Warming requires two-three hard brakings.
I don't want to come back to old proportioning valve as in fact it was something wrong with it. I would like to use adjustable valve which would allow for splitting braking power according to driving conditions. I found that such valves are very cheap (Summit Racing and Wilwood ones are for less than 40$) They allow for 57% of pressure reduction.
Does any of you has experience with those devices? Do they work well on 75/Milano?
I would appreciate any input.
