There are no drain lines around the trunk as far as I know. There's vents under the C-pillar trim to let air in/out, but that's it.
If you're getting water in the trunk, common points of entry are:
1) Trunk seal not sealing
2) Seals on taillights decayed or not tight
3) Ingress through the C-pillar vent (can happen if the trim piece was removed and not properly reattached)
4) Leakage around the rear window
I ended up pulling the trunk trim and getting in there with a flashlight and a walkie talkie. Then I sealed myself in and had my wife spray everything with the hose until I found the leaks. Not a job for the large or claustrophobic.
In my case, turned out to be one of the C-pillar vents and part of the seal around the rear window. Much easier to fix than to find, let me tell you.
1991 Spider
1987 Milano Gold
