As summer is approching Australia, I wanted to improve / reduce the running temp of my engine, she gets a little hot (85-90'C) when cruising around at low speed & in traffic. (well i guess most cars do..)
I had my radiator internals cleaned (about $50) + flush + potent mix of coolent. My dad & i also looked for a low temp thermostat but this proved a little hard to get locally despite my old man being in the trade.
We removed the thermostat which is inbedded in the housing (pic 1) for inspection. There are 3 bolts holding the thermostat housing to the water flang.
Thermostat worked well after a couple of tests using some boiling water.
Careful not to damage the gasket, we then removed the thermostat & drilled out / increased the size of the coolent drip holes, by about 2-2.5 times to what they originally were (pic 2). The coolent drip holes are quite small & wouldn't appear to let much coolent circulate to the engine until the thermostat operates.
We then cleaned up the thermostat with running water and some high pressure air (pic 3) & used high pressure air to remove any water that sat in the bolt holes in the water flang. A little bit of silastic on the gaskit, close it up and your done.
Increasing the coolent holes may also be failsafe in a way against overheating; should the thermostat fail there should still be an adequete supply of coolent circulation...at least thats what we think
My findings are as follows (using my temp gauge as indication)-
The car no longer gets to 90'C, sits no more than 80'C
It takes longer for the engine temp to hit 80'C
The engine stays cooler <80'C when driving around at lower speed.
Yes we could have put a bigger radiator in with twin fans & a low
temp thermostat but i didnt really want to spend the $$ to do this...
If anyone has any comments...
