#16 (permalink)
Old 11-05-2006, 01:22 PM
sainato59 sainato59 is offline
never thought of it that way but sounds logical and thanks for the article. i'll talk with the person who did it while i check out the rest fo the suspension stuff.
thanks for all the help.
anything else i should know?
1973 GTV 2000(Red)
1974 GTV 2000(Burgundy)
1978 Alfetta Sport Sedan(Dark Metallic Red/Burgundy)
[COLOR="Red"]Daily Drivers:[/COLOR]
1988 Milano Verde(my son's-Black)
1995 164 LS(Black)
At my House in Italy:
2001 156 1.8 Twin Spark(Black)
Parts cars, let me know if you need any parts:
1979 Alfetta Coupe
1987 Milano Gold
  #17 (permalink)
Old 11-22-2006, 08:44 PM
Balocco211's Avatar
Balocco211 Balocco211 is offline
Drive it like you stole it!
  #18 (permalink)
Old 11-24-2006, 09:07 AM
oh im already there haha
1973 GTV 2000(Red)
1995 164 LS(Black)
1979 Alfetta Coupe
1987 Milano Gold
  #19 (permalink)
Old 12-02-2006, 10:14 PM
andrewg's Avatar
andrewg andrewg is offline
Most of you have overlooked an even more basic possibility. The GTV6/Milano from the factory both spec the toe to have toe-out. On a completely stock car running the factory alignment settings, you will experience greater tire wear on the side edges of the tires. If the car has been lowered, then it only worst, because if there are not any shims then there is not way to get neg camber out unless you shorten the lower a-arm spacers. Have the alignment checked and make sure camber is closest to the positive side of it range. Also have them set the toe to zero, not toe-out as listed in the factory specs. Caster only affects straight line stability and will not wear out tires, but any good alignment shop should give you readings on toe, caster, and camber. Hope this helps.
ANDREWG
[url]www.garciaalfaracing.com[/url]
73 GTV - new restoration project
82 GTV6 ITS #86
85 Spider Graduate
88 Milano Verde - needs a motor, hum...
91 164S Recaro
  #20 (permalink)
Old 12-02-2006, 11:16 PM
JoeCab's Avatar
JoeCab JoeCab is offline
Only very early Milano literature specs toe-out. Later factory specs were for 1/16" toe in, IIRC.
Joe
