Well the rear brake compensator helped but.........the clutch still gets sucked down and now does it even further. I have also noticed clutch fluid on my shoe! It looks like it is leaking into the passenger area (very slowly) down the clutch pedal. Any ideas to cause? OR fix?
Originally posted by Publio the clutch still gets sucked down and now does it even further. I have also noticed clutch fluid on my shoe!
Bad master-cylinder from the clutch.
You can see it when you open the hood. He´s beside the brake-cylinder.
He´s fixed with two srews...and also with a bold to the cluthpedal.
The fluid can drop into the inside...cylinder>rod>pedal
