Old 12-10-2003, 06:50 PM
Hit an Apex's Avatar
Hit an Apex Hit an Apex is offline
Aftermarket (Steering) Wheels
Can someone explain the concept/whole installation of an aftermarket steering wheel along with what a hub is and what you do about the horn and more importantly - where i can get a cool aftermarket steering wheel.
Old 12-10-2003, 08:28 PM
AlfaRacer75's Avatar
AlfaRacer75 AlfaRacer75 is offline
The hub is what adapts the aftermarket wheel to fit your car. Most aftermarket steering wheels include a horn button.
Installation is pretty easy. Pop off the center/horn part of the stock wheel, remove the large nut, and use a steering wheel puller to yank it off. Then you just slide the hub on there, tighten down the nut, and bolt the new wheel to the hub.
I got my Milano Momo hub on ebay, it's made by OMP I think. Momo might make them too...
Chip Mutza
[URL=http://www.alfabb.com/bb/forums/showthread.php?t=16221]'87 Milano 3.0L 24v[/URL]
[url] http://www.fastalfas.com [/url]
Old 12-11-2003, 01:10 AM
BigSwede's Avatar
BigSwede BigSwede is offline
It's easy if you have the right puller, otherwise its hell...
Mats Strandberg
Old 12-11-2003, 07:49 AM
alfanfl alfanfl is offline
What's the right puller?
Old 12-11-2003, 08:27 AM
BigSwede's Avatar
The one that works?
What do you mean?
Mats Strandberg
Old 12-11-2003, 08:43 AM
Is there a special Alfa tool that must be used?
Or a specific type of puller?
Old 12-11-2003, 09:07 AM
papajam's Avatar
papajam papajam is online now
I use a universal type steering wheel puller with two custom 6mm bolts for 105/115 steering wheels. Can post a pic if you'd like.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 12-11-2003, 09:49 AM
ar1750gtv's Avatar
ar1750gtv ar1750gtv is offline
Jim,
Please post a picture of your "custom" puller. I may fabricate one of my own.
Thanks.
'69 1750 GTV
Cogito, ergo Alfa Romeo
Old 12-11-2003, 03:52 PM
I managed to use a standard 3 arm puller to remove my old stock wheel. Wasn't very easy though...
Chip Mutza
Old 12-11-2003, 04:05 PM
Ok recap.
Buy wheel/hub
pop center part off
remove large nut
use steering wheel puller to do what???
also does the new wheel with horn button just magically work? sensors? or are wires involved?
Old 12-11-2003, 04:08 PM
The steering wheel is a press fit onto the shaft... that's why you need a puller.
To make the horn work you just attach the existing wires to the new horn button.
Chip Mutza
Old 12-11-2003, 04:29 PM
does attaching include a wire crimper?
BTW, thanks for all the help
also will any aftermarket wheel work with a hub/
Old 12-11-2003, 04:35 PM
You shouldn't need a wire crimper for this job...
Different wheel manufacturers have different bolt patterns on the wheel, so you should get a hub from the makers of the wheel you want.
Chip Mutza
  #14 (permalink)
Old 12-11-2003, 05:45 PM
papajam's Avatar
Here's a standard, off the shelf steering wheel puller with two not-so-standard bolts for pulling Alfa steering wheels. The shorter one is an 8 x 1.25 x 75mm bolt that's been ground down and rethreaded to 6 x 1.0mm for the first 12mm or so. The longer one is a 7/16" x 4" stud with a 6 x 1.0 x 25mm headless bolt welded to end. You will need two of either style to pull the wheel. The two 'bolts' screw into two threaded holes in the steering wheel hub while the swiveling end of the large puller bolt 'pushes' on the steering shaft.
  #15 (permalink)
Old 12-12-2003, 05:51 AM
BigSwede's Avatar
or you can use a large hammer/sledgehammer. one person sitting in the driverseat and pulling the steeringwhhel and another hitting the axle. Usually pops the wheel right off.
Mats Strandberg
