Hi Folks,
Just thought that I would let you all know that I am headed back to the US here again in about two weeks with many extra performance parts for 12 valve and 24 valve Milano/GTV6/164 cars! (And some 4-banger stuff...)
Most parts were developed by legendary Alfa-man Dawie de Villiers of Glenwood Motors-fame down here in South Africa and I have used and tested ALL of it in my own cars on the street and on the track... I am bringing as follows;
Proprietary Group 1 profile cams for 12 valve engines (works well in any displacement from 2.5 to 3.0 to 3.2 to 3.5 to 3.7 litres) in a Milano, in a GTV6 or in a 164 B/L.
GTA 3.2 profile cams for the 3.0 24 valve motors found in the 164 LS - again - works well in ANY 24 valve from 3.0 to 3.7 - turns any 24 valve in a GTV6 or Milano in to a fun little motor...
Fully-programmable, stand-alone engine management systems from GoTech - controls fuel AND spark - comes with custom made Alfa/Bosch-specific plug and play wiring harnesses, program CD, manual etc. Base Standard versions as well as the PRO boxes which allows running coil-packs (even retrofitting coil-packs to 12 valvers and running 60 minus 2 crank-triggers a la 164 - in a Milano or a GTV6.)
Headers for 12 valve engines in Milano/GTV6 cars.
Oval-port headers to run 24 valve engines in Milano/GTV6 cars.
Performance heads for 12 valve and 24 valve engines (requires fresh-rebuilds of 12 valve bottom-ends as vacuum is increased and weak sub-assemblies show up when increasing performance up top...)
Large-bore intake plenums converted to 50mm with cast - very stock-looking - but huge aluminium intake runners for Milano/GTV6 cars (especially good for 3.0+ engines!)
Set of cast side-draught intake throttle-bodies to convert any NORD 4 cylinder Alfa engine to full electronic EFI - electronically control with the above-mentioned GoTech engine management system or other...
Wheel-spacers to convert a Milano/GTV6 5x98 wheel-pattern to a BMW 5x100 wheel-pattern for a greater variety in wheel selections!
Big-bore engines - built to order - now would be the time to contact me... I brought Ross Racing aluminium-alloy pistons,
Total Seal Competition Rings, Pauter forged steel chrome molly connecting rods with me.
What else? Email me at
john@reginaceleste.com with specific inquiries - maybe I can source/fill other requests here while I am local. Some of the above-mentioned items I only have a single set of such as the wheel-spacers and the large-bore intake-plenum and cast aluminium intake runners... After October 13th I can be reached on my US cell phone again at 425.941.4747. You can also PM me here on the BB however, I do prefer email/phone.
Cheers, JvR
